change the layer from a block
can I change with my program the layer from a block (objBlock) without a
separate
program with the AcadBlockReference?
Hartmut Callies
Dim objBlock As AcadBlock
Dim objEntity As AcadEntity
Dim i as Integer
For i = 0 To ThisDrawing.Blocks.Count - 1
Set objBlock = ThisDrawing.Blocks(i)
'<===== objBlock.Item(objBlock.Name).Layer = "DIM" 'how can I
change the Layer from the block?
For Each objEntity In objBlock
Next
Next i
I might be misunderstanding you, but a Block object does _not_ have a layer.
Objects within the block will have layers, and block insertions will have
layers, but not blocks themselves.
R. Robert Bell
"Hartmut Callies" wrote in message
news:5436614@discussion.autodesk.com...
separate
Hartmut Callies
Dim i as Integer
Next
Next i
