Change Text
Change Text
Change Text
Has anyone put this .lsp into vba yet? Or is it possible? (prompt"\n \n \n Loading CHTEXT.LSP file. One Moment Please...")(princ) ;;;--------------------------------------------------------------------------; ;;; CHTEXT.lsp ;;; Copyright (C) 1990 by Autodesk, Inc ;;; Copyright (C) 1991 by Control Systems, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software and its ;;; documentation for any purpose and without fee is hereby granted. ;;; ;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY. ;;; ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR PURPOSE AND OF ;;; MERCHANTABILITY ARE HEREBY DISCLAIMED. ;;; ;;; by Jan S. Yoder ;;; 09 March 1990 ;;; ;;; Modified for FLEXICON usage by ARTIST Software - December 1991 ;;; If FLEXVAR=1, call the appropriate FLEXICON MENU. ;;; ;;;--------------------------------------------------------------------------; ;;; DESCRIPTION ;;; This is a "text processor" which operates in a global manner ;;; on all of the text entities that the user selects; i.e., the ;;; Height, Justification, Location, Rotation, Style, Text, and ;;; Width can all be changed globally or individually, and the ;;; range of values for a given parameter can be listed. ;;; ;;; The command is called with CHT from the command line at which ;;; time the user is asked to select the objects to change. ;;; ;;; Select text to change. ;;; Select objects: ;;; ;;; If nothing is selected the message "ERROR: Nothing selected." ;;; is displayed and the command is terminated. If more than 25 ;;; entities are selected the following message is displayed while ;;; the text entities are sorted out from the non-text entities. ;;; A count of the text entities found is then displayed. ;;; ;;; Verifying the selected entities -- please wait. ;;; nnn text entities found. ;;; CHText: Height/Justification/Location/Rotation/Style/Text/Undo/Width: ;;; ;;; A typical example of the prompts you may encounter follows: ;;; ;;; If you select a single text entity to change and ask to change ;;; the height, the prompt looks like this: ;;; ;;; CHText: Height/Justification/Location/Rotation/Style/Text/Undo/Width: ;;; New text height for text entity. <0.08750000>: ;;; ;;; If you select more than one text entity to change and ask to change ;;; the height, the prompt looks like this: ;;; ;;; CHText: Height/Justification/Location/Rotation/Style/Text/Undo/Width: ;;; Individual/List/: ;;; ;;; Typing "L" at this prompt returns a prompt showing you the range of ;;; values that you are using for your text. ;;; ;;; Height -- Min: 0.05000000 Max: 0.10000000 Ave: 0.08392857 ;;; ;;; Typing "I" at this prompt puts you in a loop, processing the text ;;; entities you have selected one at a time, and giving the same prompt ;;; you get for a single text entity shown above. ;;; ;;; Pressing RETURN at this point puts you back at the Command: prompt. ;;; Selecting any of the other options allows you to change the text ;;; entities selected. ;;; ;;; All of the Release 11 text alignment options have been supported. ;;; This is based on the system variable "DIMCLRD" being present. ;;; If it is not present, then only the Release 10 alignment options ;;; are allowed. ;;; ;;;---------------------------------------------------------------------------; ;;; ;;; Flexicon call routine ;;; (defun flexmnu (a) (if (= FLEXVAR 1) (command "FLEXICON" (strcat "FLEX" a)) ) ) (defun gtnum () (if (and(= flexvar 1)(/= gtads 1))(command "FLEXICON" "FLEXNUMN")) ) (defun gtyn () (if (and(= flexvar 1)(/= gtads 1))(command "FLEXICON" "FLEXYN")) ) ;;;---------------------------------------------------------------------------; ;;; ;;; Main function -- no arguments ;;; (defun chtxt (/ sset opt ssl nsset temp unctr sslen style hgt rot txt ent cht_oc loc loc1 justp justq orthom ) (setq pt_ver "1.01") ; Reset this local if you make a change. ; Modified by ARTIST Software ;; ;; Internal error handler defined locally ;; (defun cht_er (s) ; If an error (such as CTRL-C) occurs ; while this command is active... (if (/= s "Function cancelled") (if (= s "quit / exit abort") (princ) (princ (strcat "\nError: " s)) ) ) (eval(read U:E)) (if cht_oe ; If an old error routine exists (setq *error* cht_oe) ; then, reset it ) (if cht_oc (setvar "cmdecho" cht_oc)) ; Reset command echoing (if cht_ot (setvar "texteval" cht_ot)) (if cht_oh (setvar "highlight" cht_oh)) (setq flexvar 0) (princ) ) ;; ;; Body of function ;; (if *error* ; Set our new error handler (setq cht_oe *error* *error* cht_er) (setq *error* cht_er) ) ;; Set undo groups and ends with (eval(read U:G)) or (eval(read U:E)) (setq U:G "(command \"undo\" \"group\")" U:E "(command \"undo\" \"end\")" ) (setq cht_oc (getvar "cmdecho")) (setq cht_oh (getvar "highlight")) (setvar "cmdecho" 0) (eval(read U:G)) (princ (strcat "\nChange text, Version " pt_ver ", (c) 1990 by Autodesk, Inc. ")) (prompt "\nSelect text to change. ") (setq sset (ssget)) (if (null sset) (progn (princ "\nERROR: Nothing selected.") (exit) ) ) ;; Verify the entity set. (cht_ve) ;; This is the main option loop. (cht_ol) (if cht_oe (setq *error* cht_oe)) ; Reset old error function if error (eval(read U:E)) (if cht_ot (setvar "texteval" cht_ot)) (if cht_oh (setvar "highlight" cht_oh)) (if cht_oc (setvar "cmdecho" cht_oc)) ; Reset command echoing (princ) ) ;;; ;;; Verify and sort out non-text entities from the selection set. ;;; (defun cht_ve () (setq ssl (sslength sset) nsset (ssadd)) (if (> ssl 25) (prompt "\nVerifying the selected entities -- please wait. ") ) (while (> ssl 0) (setq temp (ssname sset (setq ssl (1- ssl)))) (if (= (cdr(assoc 0 (entget temp))) "TEXT") (ssadd temp nsset) ) ) (setq ssl (sslength nsset) sset nsset unctr 0 ) (prompt (strcat (rtos ssl 2 0) " text entities found. ")) ) ;;; ;;; The option loop. ;;; (defun cht_ol () (setq opt T) (while (and opt (> ssl 0)) (setq unctr (1+ unctr)) (command "undo" "group") (flexmnu "CTXT") (initget "Location Justification Style Height Rotation Width Text Undo") (setq opt (getkword "\nHeight/Justification/Location/Rotation/Style/Text/Undo/Width: ")) (if opt (cond ((= opt "Undo") (cht_ue) ; Undo the previous command. ) ((= opt "Location") (cht_le) ; Change the location. ) ((= opt "Justification") (cht_je) ; Change the justification. ) ((= opt "Style") (cht_pe "Style" "style name" 7) ) ((= opt "Height") (cht_pe "Height" "height" 40) ) ((= opt "Rotation") (cht_pe "Rotation" "rotation angle" 50) ) ((= opt "Width") (cht_pe "Width" "width factor" 41) ) ((= opt "Text") (cht_te) ; Change the text. ) ) (setq opt nil) ) (command "undo" "end") ) ) ;;; ;;; Undo an entry. ;;; (defun cht_ue () (if (> unctr 1) (progn (command "undo" "end") (command "undo" "2") (setq unctr (- unctr 2)) ) (progn (princ "\nNothing to undo. ") (setq unctr (- unctr 1)) ) ) ) ;;; ;;; Change the location of an entry. ;;; (defun cht_le () (setq sslen (sslength sset) style "" hgt "" rot "" txt "" ) (command "change" sset "" "") (while (> sslen 0) (setq ent (entget(ssname sset (setq sslen (1- sslen)))) opt (list (cadr (assoc 11 ent)) (caddr (assoc 11 ent)) (cadddr (assoc 11 ent))) ) (prompt "\nNew text location: ") (command pause) (if (null loc) (setq loc opt) ) (command style hgt rot txt) ) (command) ) ;;; ;;; Change the justification of an entry. ;;; (defun cht_je () (flexmnu "TOPS") (if (getvar "DIMCLRD") (initget (strcat "TLeft TCenter TRight " "MLeft MCenter MRight " "BLeft BCenter BRight " "Aligned Center Fit Left Middle Right ?")) (initget "Aligned Center Fit Left Middle Right ?") ) (setq sslen (sslength sset)) (setq justp (getkword (strcat "\nJustification point(s) - " "Aligned/Center/Fit/Left/Middle/Right/: "))) (cond ((= justp "Left") (setq justp 0 justq 0) ) ((= justp "Center") (setq justp 1 justq 0) ) ((= justp "Right") (setq justp 2 justq 0) ) ((= justp "Aligned") (setq justp 3 justq 0) ) ((= justp "Fit") (setq justp 5 justq 0) ) ((= justp "TLeft") (setq justp 0 justq 3) ) ((= justp "TCenter") (setq justp 1 justq 3) ) ((= justp "TRight") (setq justp 2 justq 3) ) ((= justp "MLeft") (setq justp 0 justq 2) ) ((= justp "Middle") (setq justp 1 justq 2) ) ((= justp "MCenter") (setq justp 1 justq 2) ) ((= justp "MRight") (setq justp 2 justq 2) ) ((= justp "BLeft") (setq justp 0 justq 1) ) ((= justp "BCenter") (setq justp 1 justq 1) ) ((= justp "BRight") (setq justp 2 justq 1) ) ((= justp "?") (setq justp nil) ) (T (setq justp nil) ) ) (if justp (justpt) ; Process them... (justpn) ; List options... ) (command) ) ;;; ;;; Get alignment points for "aligned" or "fit" text. ;;; (defun justpt () (while (> sslen 0) (setq ent (entget(ssname sset (setq sslen (1- sslen)))) ent (subst (cons 72 justp) (assoc 72 ent) ent) opt (trans (list (cadr (assoc 11 ent)) (caddr (assoc 11 ent)) (cadddr (assoc 11 ent))) (cdr(assoc -1 ent)) ; from ECS 1) ; to current UCS ) (if (getvar "DIMCLRD") (setq ent (subst (cons 73 justq) (assoc 73 ent) ent)) ) (cond ((or (= justp 3) (= justp 5)) (prompt "\nNew text alignment points: ") (if (= (setq orthom (getvar "orthomode")) 1) (setvar "orthomode" 0) ) (redraw (cdr(assoc -1 ent)) 3) (initget 1) (setq loc (getpoint)) (initget 1) (setq loc1 (getpoint loc)) (redraw (cdr(assoc -1 ent)) 1) (setvar "orthomode" orthom) (setq ent (subst (cons 10 loc) (assoc 10 ent) ent)) (setq ent (subst (cons 11 loc1) (assoc 11 ent) ent)) ) ((/= justp 0) (redraw (cdr(assoc -1 ent)) 3) (prompt "\nNew text location: ") (if (= (setq orthom (getvar "orthomode")) 1) (setvar "orthomode" 0) ) (setq loc (getpoint opt)) (setvar "orthomode" orthom) (redraw (cdr(assoc -1 ent)) 1) (if (null loc) (setq loc opt) (setq loc (trans loc 1 (cdr(assoc -1 ent)))) ) (setq ent (subst (cons 11 loc) (assoc 11 ent) ent)) ) ) (entmod ent) ) ) ;;; ;;; List the options. ;;; (defun justpn () (if (getvar "DIMCLRD") (textpage)) (princ "\nAlignment options: ") (princ "\n\t TLeft TCenter TRight ") (princ "\n\t MLeft MCenter MRight ") (princ "\n\t BLeft BCenter BRight ") (princ "\n\t Left Center Right") (princ "\n\tAligned Middle Fit") (if (not (getvar "DIMCLRD")) (textscr)) (princ "\n\nPress any key to return to your drawing. ") (grread) (princ "\r ") (graphscr) ) ;;; ;;; Change the text of an entity. ;;; (defun cht_te () (setq sslen (sslength sset)) (flexmnu "CHT2") (initget "Globally Individually Retype") (setq ans (getkword "\nSearch and replace text. Individually/Retype/:")) (setq cht_ot (getvar "texteval")) (setvar "texteval" 1) (cond ((= ans "Individually") (if (= (getvar "popups") 1) (progn (gtyn) (prompt "\nEdit text in dialogue? : ") (initget "Yes No") (setq ans (if(= flexvar gtads 1) (gt_yesno"Edit text in dialogue? :")(getkword))) ) (setq ans "No") ) (while (> sslen 0) (redraw (setq sn (ssname sset (setq sslen (1- sslen)))) 3) (setq ss (ssadd)) (ssadd (ssname sset sslen) ss) (if (= ans "No") (chgtext ss) (command "ddedit" sn "") ) (redraw sn 1) ) ) ((= ans "Retype") (while (> sslen 0) (setq ent (entget(ssname sset (setq sslen (1- sslen))))) (redraw (cdr(assoc -1 ent)) 3) (prompt (strcat "\nOld text: " (cdr(assoc 1 ent)))) (setq nt (getstring T "\nNew text: ")) (redraw (cdr(assoc -1 ent)) 1) (if (> (strlen nt) 0) (entmod (subst (cons 1 nt) (assoc 1 ent) ent)) ) ) ) (T (chgtext sset) ; Change 'em all ) ) (setvar "texteval" cht_ot) ) ;;; ;;; The old CHGTEXT command - rudimentary text editor ;;; ;;; (defun C:CHGTEXT () (chgtext nil)) (defun chgtext (objs / last_o tot_o ent o_str n_str st s_temp n_slen o_slen si chf chm cont ans) (if (null objs) (setq objs (ssget)) ; Select objects if running standalone ) (setq chm 0) (if objs (progn ; If any objects selected (if (= (type objs) 'ENAME) (progn (setq ent (entget objs)) (princ (strcat "\nExisting string: " (cdr (assoc 1 ent)))) ) (if (= (sslength objs) 1) (progn (setq ent (entget (ssname objs 0))) (princ (strcat "\nExisting string: " (cdr (assoc 1 ent)))) ) ) ) (setq o_str (getstring "\nMatch string : " t)) (setq o_slen (strlen o_str)) (if (/= o_slen 0) (progn (setq n_str (getstring "\nNew string : " t)) (setq n_slen (strlen n_str)) (setq last_o 0 tot_o (if (= (type objs) 'ENAME) 1 (sslength objs) ) ) (while (< last_o tot_o) ; For each selected object... (if (= "TEXT" ; Look for TEXT entity type (group 0) (cdr (assoc 0 (setq ent (entget (ssname objs last_o)))))) (progn (setq chf nil si 1) (setq s_temp (cdr (assoc 1 ent))) (while (= o_slen (strlen (setq st (substr s_temp si o_slen)))) (if (= st o_str) (progn (setq s_temp (strcat (if (> si 1) (substr s_temp 1 (1- si)) "" ) n_str (substr s_temp (+ si o_slen)) ) ) (setq chf t) ; Found old string (setq si (+ si n_slen)) ) (setq si (1+ si)) ) ) (if chf (progn ; Substitute new string for old ; Modify the TEXT entity (entmod (subst (cons 1 s_temp) (assoc 1 ent) ent)) (setq chm (1+ chm)) ) ) ) ) (setq last_o (1+ last_o)) ) ) ;; else go on to the next line... ) ) ) (if (/= (type objs) 'ENAME) (if (/= (sslength objs) 1) ; Print total lines changed (princ (strcat "Changed " (rtos chm 2 0) " text lines." ) ) ) ) (terpri) ) ;;; ;;; Main procedure for manipulating text entities ;;; ARGUMENTS: ;;; typ -- Type of operation to perform ;;; prmpt -- Partial prompt string to insert in standard prompt line ;;; fld -- Assoc field to be changed ;;; GLOBALS: ;;; sset -- The selection set of text entities ;;; (defun cht_pe (typ prmpt fld / temp ow nw ent tw sty w hw lw sslen n sn ssl) (if (= (sslength sset) 1) ; Special case if there is only ; one entity selected ;; Process one entity. (cht_p1) ;; Else (progn ;; Set prompt string. (cht_sp) (if (= nw "List") ;; Process List request. (cht_pl) (if (= nw "Individual") ;; Process Individual request. (cht_pi) (if (= nw "Select") ;; Process Select request. (cht_ps) ;; Else (progn (if (= typ "Rotation") (setq nw (* (/ nw 180.0) pi)) ) (if (= (type nw) 'STR) (if (not (tblsearch "style" nw)) (progn (princ (strcat "\nStyle " nw " not found. ")) ) (cht_pa) ) (cht_pa) ) ) ) ) ) ) ) ) ;;; ;;; Change all of the entities in the selection set. ;;; (defun cht_pa () (setq sslen (sslength sset)) (setq cht_ot (getvar "texteval")) (setvar "highlight" 0) (while (> sslen 0) (setq temp (ssname sset (setq sslen (1- sslen)))) (entmod (subst (cons fld nw) (assoc fld (setq ent (entget temp))) ent ) ) ) (setvar "highlight" cht_oh) ) ;;; ;;; Change one text entity. ;;; (defun cht_p1 () (setq temp (ssname sset 0)) (setq ow (cdr(assoc fld (entget temp)))) (if (= opt "Rotation") (setq ow (/ (* ow 180.0) pi)) ) (redraw (cdr(assoc -1 (entget temp))) 3) (initget 0) (if (= opt "Style") (progn (if (= flexvar gtads 1) (progn (prompt(strcat "\nNew " prmpt ". <" ow ">: ")) (setq nw (gttable "STYLE")) ) (setq nw (getstring (strcat "\nNew " prmpt ". <" ow ">: "))) ) ) (progn (gtnum) (prompt (strcat "\nNew " prmpt ". <" (rtos ow 2) ">: ")) (setq nw (if(= flexvar gtads 1) (gtfnum(strcat"\nNew "prmpt". <" (rtos ow 2) ">: ")) (getreal) ) ) ) ) (if (or (= nw "") (= nw nil)) (setq nw ow) ) (redraw (cdr(assoc -1 (entget temp))) 1) (if (= opt "Rotation") (setq nw (* (/ nw 180.0) pi)) ) (if (= opt "Style") (if (null (tblsearch "style" nw)) (princ (strcat "\nStyle " nw " not found. ")) (entmod (subst (cons fld nw) (assoc fld (setq ent (entget temp))) ent ) ) ) (entmod (subst (cons fld nw) (assoc fld (setq ent (entget temp))) ent ) ) ) ) ;;; ;;; Set the prompt string. ;;; (defun cht_sp () (if (= typ "Style") (progn (flexmnu "CHTS") (initget "Individual List New Select ") (setq nw (getkword (strcat "\nIndividual/List/Select style/: "))) (if (or (= nw "") (= nw nil) (= nw "Enter")) (setq nw (getstring (strcat "\nNew " prmpt " for all text entities: "))) ) ) (progn (flexmnu "CHGT") (initget "List Individual" 1) (setq nw (getreal (strcat "\nIndividual/List/: "))) ) ) ) ;;; ;;; Process List request. ;;; (defun cht_pl () (setq unctr (1- unctr)) (setq sslen (sslength sset)) (setq tw 0) (while (> sslen 0) (setq temp (ssname sset (setq sslen (1- sslen)))) (if (= typ "Style") (progn (if (= tw 0) (setq tw (list (cdr(assoc fld (entget temp))))) (progn (setq sty (cdr(assoc fld (entget temp)))) (if (not (member sty tw)) (setq tw (append tw (list sty))) ) ) ) ) (progn (setq tw (+ tw (setq w (cdr(assoc fld (entget temp)))))) (if (= (sslength sset) (1+ sslen)) (setq lw w hw w)) (if (< hw w) (setq hw w)) (if (> lw w) (setq lw w)) ) ) ) (if (= typ "Rotation") (setq tw (* (/ tw pi) 180.0) lw (* (/ lw pi) 180.0) hw (* (/ hw pi) 180.0)) ) (if (= typ "Style") (progn (princ (strcat "\n" typ "(s) -- ")) (princ tw) ) (princ (strcat "\n" typ " -- Min: " (rtos lw 2) "\t Max: " (rtos hw 2) "\t Avg: " (rtos (/ tw (sslength sset)) 2) )) ) ) ;;; ;;; Process Individual request. ;;; (defun cht_pi () (setq sslen (sslength sset)) (while (> sslen 0) (setq temp (ssname sset (setq sslen (1- sslen)))) (setq ow (cdr(assoc fld (entget temp)))) (if (= typ "Rotation") (setq ow (/ (* ow 180.0) pi)) ) (initget 0) (redraw (cdr(assoc -1 (entget temp))) 3) (if (= typ "Style") (progn (if (= flexvar gtads 1) (progn (prompt(strcat "\nNew " prmpt ". <" ow ">: ")) (setq nw (gttable "STYLE")) ) (setq nw (getstring (strcat "\nNew " prmpt ". <" ow ">: "))) ) ) (progn (gtnum) (prompt(strcat "\nNew " prmpt ". <" (rtos ow 2) ">: ")) (setq nw (if(= flexvar gtads 1) (gtfnum(strcat"\nNew "prmpt". <"(rtos ow 2)">:")) (getreal) ) ) ) ) (if (or (= nw "") (= nw nil)) (setq nw ow) ) (if (= typ "Rotation") (setq nw (* (/ nw 180.0) pi)) ) (entmod (subst (cons fld nw) (assoc fld (setq ent (entget temp))) ent ) ) (redraw (cdr(assoc -1 (entget temp))) 1) ) ) ;;; ;;; Process the Select option. ;;; (defun cht_ps () (princ "\nSearch for which Style name? <*>: ") (setq sn (strcase (getstring)) n -1 sset nsset nsset (ssadd) ssl (1- (sslength sset)) ) (if (or (= sn "*") (null sn) (= sn "")) (setq nsset sset sn "*") (while (and sn (< n ssl)) (setq temp (ssname sset (setq n (1+ n)))) (if (= (cdr(assoc 7 (entget temp))) sn) (ssadd temp nsset) ) ) ) (setq ssl (sslength nsset)) (princ "\nFound ") (princ ssl) (princ " text entities with STYLE of ") (princ sn) (princ ". ") (setq sset nsset) ) ;;; ;;; The C: function definition. ;;; (defun c:cht () (chtxt)) (princ "\n\tc:CHText loaded. Start command with CHT.") (princ) Brent Daley CAD Manager RD Engineering, Inc. 11920 Burt Street, Suite 180 Omaha, NE 68154 Phone: 402.505.4355 Cell: 402.981.3713 Fax: 402.505.4432 Email: bdaley@rdengineering-inc.com
Hi Brent, This is lisp. Hence the answer to your question is obvious. From the description of functions it would seem to superseded by the properties features of later versions of AutoCAD. -- Regards, Laurie Comerford www.cadapps.com.au "Brent Daley" wrote in message news:42010f5a_3@newsprd01... > Has anyone put this .lsp into vba yet? Or is it possible? > > (prompt"\n \n \n Loading CHTEXT.LSP file. One Moment Please...")(princ) > ;;;--------------------------------------------------------------------------; > ;;; CHTEXT.lsp > ;;; Copyright (C) 1990 by Autodesk, Inc > ;;; Copyright (C) 1991 by Control Systems, Inc. > ;;; > ;;; Permission to use, copy, modify, and distribute this software and > its > ;;; documentation for any purpose and without fee is hereby granted. > ;;; > ;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED > WARRANTY. > ;;; ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR PURPOSE AND OF > ;;; MERCHANTABILITY ARE HEREBY DISCLAIMED. > ;;; > ;;; by Jan S. Yoder > ;;; 09 March 1990 > ;;; > ;;; Modified for FLEXICON usage by ARTIST Software - December 1991 > ;;; If FLEXVAR=1, call the appropriate FLEXICON MENU. > ;;; > ;;;--------------------------------------------------------------------------; > ;;; DESCRIPTION > ;;; This is a "text processor" which operates in a global manner > ;;; on all of the text entities that the user selects; i.e., the > ;;; Height, Justification, Location, Rotation, Style, Text, and > ;;; Width can all be changed globally or individually, and the > ;;; range of values for a given parameter can be listed. > ;;; > ;;; The command is called with CHT from the command line at which > ;;; time the user is asked to select the objects to change. > ;;; > ;;; Select text to change. > ;;; Select objects: > ;;; > ;;; If nothing is selected the message "ERROR: Nothing selected." > ;;; is displayed and the command is terminated. If more than 25 > ;;; entities are selected the following message is displayed while > ;;; the text entities are sorted out from the non-text entities. > ;;; A count of the text entities found is then displayed. > ;;; > ;;; Verifying the selected entities -- please wait. > ;;; nnn text entities found. > ;;; CHText: > Height/Justification/Location/Rotation/Style/Text/Undo/Width: > ;;; > ;;; A typical example of the prompts you may encounter follows: > ;;; > ;;; If you select a single text entity to change and ask to change > ;;; the height, the prompt looks like this: > ;;; > ;;; CHText: > Height/Justification/Location/Rotation/Style/Text/Undo/Width: > ;;; New text height for text entity. <0.08750000>: > ;;; > ;;; If you select more than one text entity to change and ask to change > ;;; the height, the prompt looks like this: > ;;; > ;;; CHText: > Height/Justification/Location/Rotation/Style/Text/Undo/Width: > ;;; Individual/List/: > ;;; > ;;; Typing "L" at this prompt returns a prompt showing you the range of > ;;; values that you are using for your text. > ;;; > ;;; Height -- Min: 0.05000000 Max: 0.10000000 Ave: 0.08392857 > ;;; > ;;; Typing "I" at this prompt puts you in a loop, processing the text > ;;; entities you have selected one at a time, and giving the same prompt > ;;; you get for a single text entity shown above. > ;;; > ;;; Pressing RETURN at this point puts you back at the Command: prompt. > ;;; Selecting any of the other options allows you to change the text > ;;; entities selected. > ;;; > ;;; All of the Release 11 text alignment options have been supported. > ;;; This is based on the system variable "DIMCLRD" being present. > ;;; If it is not present, then only the Release 10 alignment options > ;;; are allowed. > ;;; > ;;;---------------------------------------------------------------------------; > ;;; > ;;; Flexicon call routine > ;;; > > (defun flexmnu (a) > (if (= FLEXVAR 1) > (command "FLEXICON" (strcat "FLEX" a)) > ) > ) > > (defun gtnum () > (if (and(= flexvar 1)(/= gtads 1))(command "FLEXICON" "FLEXNUMN")) > ) > (defun gtyn () > (if (and(= flexvar 1)(/= gtads 1))(command "FLEXICON" "FLEXYN")) > ) > > > ;;;---------------------------------------------------------------------------; > ;;; > ;;; Main function -- no arguments > ;;; > (defun chtxt (/ sset opt ssl nsset temp unctr > sslen style hgt rot txt ent cht_oc > loc loc1 justp justq orthom ) > > (setq pt_ver "1.01") ; Reset this local if you make a > change. > ; Modified by ARTIST Software > ;; > ;; Internal error handler defined locally > ;; > (defun cht_er (s) ; If an error (such as CTRL-C) occurs > ; while this command is active... > (if (/= s "Function cancelled") > (if (= s "quit / exit abort") > (princ) > (princ (strcat "\nError: " s)) > ) > ) > (eval(read U:E)) > (if cht_oe ; If an old error routine exists > (setq *error* cht_oe) ; then, reset it > ) > (if cht_oc (setvar "cmdecho" cht_oc)) ; Reset command echoing > (if cht_ot (setvar "texteval" cht_ot)) > (if cht_oh (setvar "highlight" cht_oh)) > (setq flexvar 0) > (princ) > ) > ;; > ;; Body of function > ;; > (if *error* ; Set our new error handler > (setq cht_oe *error* *error* cht_er) > (setq *error* cht_er) > ) > > ;; Set undo groups and ends with (eval(read U:G)) or (eval(read U:E)) > (setq U:G "(command \"undo\" \"group\")" > U:E "(command \"undo\" \"end\")" > ) > > (setq cht_oc (getvar "cmdecho")) > (setq cht_oh (getvar "highlight")) > (setvar "cmdecho" 0) > > (eval(read U:G)) > > (princ (strcat "\nChange text, Version " pt_ver > ", (c) 1990 by Autodesk, Inc. ")) > (prompt "\nSelect text to change. ") > (setq sset (ssget)) > (if (null sset) > (progn > (princ "\nERROR: Nothing selected.") > (exit) > ) > ) > ;; Verify the entity set. > (cht_ve) > ;; This is the main option loop. > (cht_ol) > > (if cht_oe (setq *error* cht_oe)) ; Reset old error function if error > (eval(read U:E)) > (if cht_ot (setvar "texteval" cht_ot)) > (if cht_oh (setvar "highlight" cht_oh)) > (if cht_oc (setvar "cmdecho" cht_oc)) ; Reset command echoing > (princ) > ) > ;;; > ;;; Verify and sort out non-text entities from the selection set. > ;;; > (defun cht_ve () > (setq ssl (sslength sset) > nsset (ssadd)) > (if (> ssl 25) > (prompt "\nVerifying the selected entities -- please wait. ") > ) > (while (> ssl 0) > (setq temp (ssname sset (setq ssl (1- ssl)))) > (if (= (cdr(assoc 0 (entget temp))) "TEXT") > (ssadd temp nsset) > ) > ) > (setq ssl (sslength nsset) > sset nsset > unctr 0 > ) > (prompt (strcat (rtos ssl 2 0) " text entities found. ")) > ) > ;;; > ;;; The option loop. > ;;; > (defun cht_ol () > (setq opt T) > (while (and opt (> ssl 0)) > (setq unctr (1+ unctr)) > (command "undo" "group") > (flexmnu "CTXT") > (initget "Location Justification Style Height Rotation Width Text > Undo") > (setq opt (getkword > "\nHeight/Justification/Location/Rotation/Style/Text/Undo/Width: ")) > (if opt > (cond > ((= opt "Undo") > (cht_ue) ; Undo the previous command. > ) > ((= opt "Location") > (cht_le) ; Change the location. > ) > ((= opt "Justification") > (cht_je) ; Change the justification. > ) > ((= opt "Style") (cht_pe "Style" "style name" 7) ) > ((= opt "Height") (cht_pe "Height" "height" 40) ) > ((= opt "Rotation") (cht_pe "Rotation" "rotation angle" 50) ) > ((= opt "Width") (cht_pe "Width" "width factor" 41) ) > ((= opt "Text") > (cht_te) ; Change the text. > ) > ) > (setq opt nil) > ) > (command "undo" "end") > ) > ) > ;;; > ;;; Undo an entry. > ;;; > (defun cht_ue () > (if (> unctr 1) > (progn > (command "undo" "end") > (command "undo" "2") > (setq unctr (- unctr 2)) > ) > (progn > (princ "\nNothing to undo. ") > (setq unctr (- unctr 1)) > ) > ) > ) > ;;; > ;;; Change the location of an entry. > ;;; > (defun cht_le () > (setq sslen (sslength sset) > style "" > hgt "" > rot "" > txt "" > ) > (command "change" sset "" "") > (while (> sslen 0) > (setq ent (entget(ssname sset (setq sslen (1- sslen)))) > opt (list (cadr (assoc 11 ent)) > (caddr (assoc 11 ent)) > (cadddr (assoc 11 ent))) > ) > (prompt "\nNew text location: ") > (command pause) > (if (null loc) > (setq loc opt) > ) > (command style hgt rot txt) > ) > (command) > ) > ;;; > ;;; Change the justification of an entry. > ;;; > (defun cht_je () > (flexmnu "TOPS") > (if (getvar "DIMCLRD") > (initget (strcat "TLeft TCenter TRight " > "MLeft MCenter MRight " > "BLeft BCenter BRight " > "Aligned Center Fit Left Middle Right ?")) > (initget "Aligned Center Fit Left Middle Right ?") > ) > (setq sslen (sslength sset)) > (setq justp (getkword (strcat "\nJustification point(s) - " > "Aligned/Center/Fit/Left/Middle/Right/: "))) > (cond > ((= justp "Left") (setq justp 0 justq 0) ) > ((= justp "Center") (setq justp 1 justq 0) ) > ((= justp "Right") (setq justp 2 justq 0) ) > ((= justp "Aligned") (setq justp 3 justq 0) ) > ((= justp "Fit") (setq justp 5 justq 0) ) > ((= justp "TLeft") (setq justp 0 justq 3) ) > ((= justp "TCenter") (setq justp 1 justq 3) ) > ((= justp "TRight") (setq justp 2 justq 3) ) > ((= justp "MLeft") (setq justp 0 justq 2) ) > ((= justp "Middle") (setq justp 1 justq 2) ) > ((= justp "MCenter") (setq justp 1 justq 2) ) > ((= justp "MRight") (setq justp 2 justq 2) ) > ((= justp "BLeft") (setq justp 0 justq 1) ) > ((= justp "BCenter") (setq justp 1 justq 1) ) > ((= justp "BRight") (setq justp 2 justq 1) ) > ((= justp "?") (setq justp nil) ) > (T (setq justp nil) ) > ) > (if justp > (justpt) ; Process them... > (justpn) ; List options... > ) > (command) > ) > ;;; > ;;; Get alignment points for "aligned" or "fit" text. > ;;; > (defun justpt () > (while (> sslen 0) > (setq ent (entget(ssname sset (setq sslen (1- sslen)))) > ent (subst (cons 72 justp) (assoc 72 ent) ent) > opt (trans (list (cadr (assoc 11 ent)) > (caddr (assoc 11 ent)) > (cadddr (assoc 11 ent))) > (cdr(assoc -1 ent)) ; from ECS > 1) ; to current UCS > ) > (if (getvar "DIMCLRD") > (setq ent (subst (cons 73 justq) (assoc 73 ent) ent)) > ) > (cond > ((or (= justp 3) (= justp 5)) > (prompt "\nNew text alignment points: ") > (if (= (setq orthom (getvar "orthomode")) 1) > (setvar "orthomode" 0) > ) > (redraw (cdr(assoc -1 ent)) 3) > (initget 1) > (setq loc (getpoint)) > (initget 1) > (setq loc1 (getpoint loc)) > (redraw (cdr(assoc -1 ent)) 1) > (setvar "orthomode" orthom) > (setq ent (subst (cons 10 loc) (assoc 10 ent) ent)) > (setq ent (subst (cons 11 loc1) (assoc 11 ent) ent)) > ) > ((/= justp 0) > (redraw (cdr(assoc -1 ent)) 3) > (prompt "\nNew text location: ") > (if (= (setq orthom (getvar "orthomode")) 1) > (setvar "orthomode" 0) > ) > (setq loc (getpoint opt)) > (setvar "orthomode" orthom) > (redraw (cdr(assoc -1 ent)) 1) > (if (null loc) > (setq loc opt) > (setq loc (trans loc 1 (cdr(assoc -1 ent)))) > ) > (setq ent (subst (cons 11 loc) (assoc 11 ent) ent)) > ) > ) > (entmod ent) > ) > ) > ;;; > ;;; List the options. > ;;; > (defun justpn () > (if (getvar "DIMCLRD") (textpage)) > (princ "\nAlignment options: ") > (princ "\n\t TLeft TCenter TRight ") > (princ "\n\t MLeft MCenter MRight ") > (princ "\n\t BLeft BCenter BRight ") > (princ "\n\t Left Center Right") > (princ "\n\tAligned Middle Fit") > (if (not (getvar "DIMCLRD")) (textscr)) > (princ "\n\nPress any key to return to your drawing. ") > (grread) > (princ "\r ") > (graphscr) > ) > ;;; > ;;; Change the text of an entity. > ;;; > (defun cht_te () > (setq sslen (sslength sset)) > (flexmnu "CHT2") > (initget "Globally Individually Retype") > (setq ans (getkword > "\nSearch and replace text. Individually/Retype/:")) > (setq cht_ot (getvar "texteval")) > (setvar "texteval" 1) > (cond > ((= ans "Individually") > (if (= (getvar "popups") 1) > (progn > (gtyn) > (prompt "\nEdit text in dialogue? : ") > (initget "Yes No") > (setq ans (if(= flexvar gtads 1) > (gt_yesno"Edit text in dialogue? :")(getkword))) > ) > (setq ans "No") > ) > > (while (> sslen 0) > (redraw (setq sn (ssname sset (setq sslen (1- sslen)))) 3) > (setq ss (ssadd)) > (ssadd (ssname sset sslen) ss) > (if (= ans "No") > (chgtext ss) > (command "ddedit" sn "") > ) > (redraw sn 1) > ) > ) > ((= ans "Retype") > (while (> sslen 0) > (setq ent (entget(ssname sset (setq sslen (1- sslen))))) > (redraw (cdr(assoc -1 ent)) 3) > (prompt (strcat "\nOld text: " (cdr(assoc 1 ent)))) > (setq nt (getstring T "\nNew text: ")) > (redraw (cdr(assoc -1 ent)) 1) > (if (> (strlen nt) 0) > (entmod (subst (cons 1 nt) (assoc 1 ent) ent)) > ) > ) > ) > (T > (chgtext sset) ; Change 'em all > ) > ) > (setvar "texteval" cht_ot) > ) > ;;; > ;;; The old CHGTEXT command - rudimentary text editor > ;;; > ;;; > (defun C:CHGTEXT () (chgtext nil)) > > (defun chgtext (objs / last_o tot_o ent o_str n_str st s_temp > n_slen o_slen si chf chm cont ans) > (if (null objs) > (setq objs (ssget)) ; Select objects if running > standalone > ) > (setq chm 0) > (if objs > (progn ; If any objects selected > (if (= (type objs) 'ENAME) > (progn > (setq ent (entget objs)) > (princ (strcat "\nExisting string: " (cdr (assoc 1 ent)))) > ) > (if (= (sslength objs) 1) > (progn > (setq ent (entget (ssname objs 0))) > (princ (strcat "\nExisting string: " (cdr (assoc 1 ent)))) > ) > ) > ) > (setq o_str (getstring "\nMatch string : " t)) > (setq o_slen (strlen o_str)) > (if (/= o_slen 0) > (progn > (setq n_str (getstring "\nNew string : " t)) > (setq n_slen (strlen n_str)) > (setq last_o 0 > tot_o (if (= (type objs) 'ENAME) > 1 > (sslength objs) > ) > ) > (while (< last_o tot_o) ; For each selected object... > (if (= "TEXT" ; Look for TEXT entity type (group 0) > (cdr (assoc 0 (setq ent (entget (ssname objs > last_o)))))) > (progn > (setq chf nil si 1) > (setq s_temp (cdr (assoc 1 ent))) > (while (= o_slen (strlen (setq st (substr s_temp si > o_slen)))) > (if (= st o_str) > (progn > (setq s_temp (strcat > (if (> si 1) > (substr s_temp 1 (1- si)) > "" > ) > n_str > (substr s_temp (+ si o_slen)) > ) > ) > (setq chf t) ; Found old string > (setq si (+ si n_slen)) > ) > (setq si (1+ si)) > ) > ) > (if chf > (progn ; Substitute new string for old > ; Modify the TEXT entity > (entmod (subst (cons 1 s_temp) (assoc 1 ent) ent)) > (setq chm (1+ chm)) > ) > ) > ) > ) > (setq last_o (1+ last_o)) > ) > ) > ;; else go on to the next line... > ) > ) > ) > (if (/= (type objs) 'ENAME) > (if (/= (sslength objs) 1) ; Print total lines changed > (princ (strcat "Changed " > (rtos chm 2 0) > " text lines." > ) > ) > ) > ) > (terpri) > ) > ;;; > ;;; Main procedure for manipulating text entities > ;;; ARGUMENTS: > ;;; typ -- Type of operation to perform > ;;; prmpt -- Partial prompt string to insert in standard prompt line > ;;; fld -- Assoc field to be changed > ;;; GLOBALS: > ;;; sset -- The selection set of text entities > ;;; > (defun cht_pe (typ prmpt fld / temp ow nw ent tw sty w hw lw > sslen n sn ssl) > (if (= (sslength sset) 1) ; Special case if there is only > ; one entity selected > ;; Process one entity. > (cht_p1) > ;; Else > (progn > ;; Set prompt string. > (cht_sp) > (if (= nw "List") > ;; Process List request. > (cht_pl) > (if (= nw "Individual") > ;; Process Individual request. > (cht_pi) > (if (= nw "Select") > ;; Process Select request. > (cht_ps) > ;; Else > (progn > (if (= typ "Rotation") > (setq nw (* (/ nw 180.0) pi)) > ) > (if (= (type nw) 'STR) > (if (not (tblsearch "style" nw)) > (progn > (princ (strcat "\nStyle " nw " not found. ")) > ) > (cht_pa) > ) > (cht_pa) > ) > ) > ) > ) > ) > ) > ) > ) > ;;; > ;;; Change all of the entities in the selection set. > ;;; > (defun cht_pa () > (setq sslen (sslength sset)) > (setq cht_ot (getvar "texteval")) > (setvar "highlight" 0) > (while (> sslen 0) > (setq temp (ssname sset (setq sslen (1- sslen)))) > (entmod (subst (cons fld nw) > (assoc fld (setq ent (entget temp))) > ent > ) > ) > > ) > (setvar "highlight" cht_oh) > ) > > ;;; > ;;; Change one text entity. > ;;; > (defun cht_p1 () > (setq temp (ssname sset 0)) > (setq ow (cdr(assoc fld (entget temp)))) > (if (= opt "Rotation") > (setq ow (/ (* ow 180.0) pi)) > ) > (redraw (cdr(assoc -1 (entget temp))) 3) > (initget 0) > (if (= opt "Style") > (progn > (if (= flexvar gtads 1) > (progn > (prompt(strcat "\nNew " prmpt ". <" ow ">: ")) > (setq nw (gttable "STYLE")) > ) > (setq nw (getstring (strcat "\nNew " prmpt ". <" ow ">: "))) > ) > ) > (progn > (gtnum) > (prompt (strcat "\nNew " prmpt ". <" (rtos ow 2) ">: ")) > (setq nw > (if(= flexvar gtads 1) > (gtfnum(strcat"\nNew "prmpt". <" (rtos ow 2) ">: ")) > (getreal) > ) > ) > ) > ) > (if (or (= nw "") (= nw nil)) > (setq nw ow) > ) > (redraw (cdr(assoc -1 (entget temp))) 1) > (if (= opt "Rotation") > (setq nw (* (/ nw 180.0) pi)) > ) > (if (= opt "Style") > (if (null (tblsearch "style" nw)) > (princ (strcat "\nStyle " nw " not found. ")) > > (entmod (subst (cons fld nw) > (assoc fld (setq ent (entget temp))) > ent > ) > ) > ) > (entmod (subst (cons fld nw) > (assoc fld (setq ent (entget temp))) > ent > ) > ) > ) > ) > ;;; > ;;; Set the prompt string. > ;;; > (defun cht_sp () > (if (= typ "Style") > (progn > (flexmnu "CHTS") > (initget "Individual List New Select ") > (setq nw (getkword (strcat "\nIndividual/List/Select style/ prmpt > " for all text entities>: "))) > (if (or (= nw "") (= nw nil) (= nw "Enter")) > (setq nw (getstring (strcat "\nNew " > prmpt > " for all text entities: "))) > ) > ) > (progn > (flexmnu "CHGT") > (initget "List Individual" 1) > (setq nw (getreal (strcat "\nIndividual/List/ prmpt > " for all text entities>: "))) > ) > ) > ) > ;;; > ;;; Process List request. > ;;; > (defun cht_pl () > (setq unctr (1- unctr)) > (setq sslen (sslength sset)) > (setq tw 0) > (while (> sslen 0) > (setq temp (ssname sset (setq sslen (1- sslen)))) > (if (= typ "Style") > (progn > (if (= tw 0) > (setq tw (list (cdr(assoc fld (entget temp))))) > (progn > (setq sty (cdr(assoc fld (entget temp)))) > (if (not (member sty tw)) > (setq tw (append tw (list sty))) > ) > ) > ) > ) > (progn > (setq tw (+ tw (setq w (cdr(assoc fld (entget temp)))))) > (if (= (sslength sset) (1+ sslen)) (setq lw w hw w)) > (if (< hw w) (setq hw w)) > (if (> lw w) (setq lw w)) > ) > ) > ) > (if (= typ "Rotation") > (setq tw (* (/ tw pi) 180.0) > lw (* (/ lw pi) 180.0) > hw (* (/ hw pi) 180.0)) > ) > (if (= typ "Style") > (progn > (princ (strcat "\n" > typ > "(s) -- ")) > (princ tw) > ) > (princ (strcat "\n" > typ > " -- Min: " > (rtos lw 2) > "\t Max: " > (rtos hw 2) > "\t Avg: " > (rtos (/ tw (sslength sset)) 2) )) > ) > ) > > ;;; > ;;; Process Individual request. > ;;; > (defun cht_pi () > (setq sslen (sslength sset)) > (while (> sslen 0) > (setq temp (ssname sset (setq sslen (1- sslen)))) > (setq ow (cdr(assoc fld (entget temp)))) > (if (= typ "Rotation") > (setq ow (/ (* ow 180.0) pi)) > ) > (initget 0) > (redraw (cdr(assoc -1 (entget temp))) 3) > (if (= typ "Style") > (progn > (if (= flexvar gtads 1) > (progn > (prompt(strcat "\nNew " prmpt ". <" ow ">: ")) > (setq nw (gttable "STYLE")) > ) > (setq nw (getstring (strcat "\nNew " > prmpt > ". <" > ow ">: "))) > ) > ) > (progn > (gtnum) > (prompt(strcat "\nNew " prmpt ". <" (rtos ow 2) ">: ")) > (setq nw > (if(= flexvar gtads 1) > (gtfnum(strcat"\nNew "prmpt". <"(rtos ow 2)">:")) > (getreal) > ) > ) > ) > ) > (if (or (= nw "") (= nw nil)) > (setq nw ow) > ) > (if (= typ "Rotation") > (setq nw (* (/ nw 180.0) pi)) > ) > (entmod (subst (cons fld nw) > (assoc fld (setq ent (entget temp))) > ent > ) > ) > (redraw (cdr(assoc -1 (entget temp))) 1) > ) > ) > ;;; > ;;; Process the Select option. > ;;; > (defun cht_ps () > (princ "\nSearch for which Style name? <*>: ") > (setq sn (strcase (getstring)) > n -1 > sset nsset > nsset (ssadd) > ssl (1- (sslength sset)) > ) > (if (or (= sn "*") (null sn) (= sn "")) > (setq nsset sset sn "*") > (while (and sn (< n ssl)) > (setq temp (ssname sset (setq n (1+ n)))) > (if (= (cdr(assoc 7 (entget temp))) sn) > (ssadd temp nsset) > ) > ) > ) > (setq ssl (sslength nsset)) > (princ "\nFound ") > (princ ssl) > (princ " text entities with STYLE of ") > (princ sn) > (princ ". ") > > (setq sset nsset) > ) > ;;; > ;;; The C: function definition. > ;;; > (defun c:cht () (chtxt)) > (princ "\n\tc:CHText loaded. Start command with CHT.") > (princ) > > Brent Daley > CAD Manager > RD Engineering, Inc. > 11920 Burt Street, Suite 180 > Omaha, NE 68154 > > Phone: 402.505.4355 > Cell: 402.981.3713 > Fax: 402.505.4432 > Email: bdaley@rdengineering-inc.com >
