Centroid of Region, VBA - need sample code to determine centroid of region
xxaaron
xxaaron
Can someone please add the necessary code to determine the centroid of the Regions region?
pi = 3.xxx-xxxxxxxx
Dim StartPoint(0 To 2) As Double
Dim EndPoint(0 To 2) As Double
Dim Line(0 To 3) As Object
StartPoint(0) = 0: StartPoint(1) = 0: StartPoint(2) = 0
EndPoint(0) = 1: EndPoint(1) = 0: EndPoint(2) = 0
Set Line(0) = ThisDrawing.ModelSpace.AddLine(StartPoint, EndPoint)
StartPoint(0) = 1: StartPoint(1) = 0: StartPoint(2) = 0
EndPoint(0) = 1: EndPoint(1) = 1: EndPoint(2) = 0
Set Line(1) = ThisDrawing.ModelSpace.AddLine(StartPoint, EndPoint)
StartPoint(0) = 1: StartPoint(1) = 1: StartPoint(2) = 0
EndPoint(0) = 0: EndPoint(1) = 1: EndPoint(2) = 0
Set Line(2) = ThisDrawing.ModelSpace.AddLine(StartPoint, EndPoint)
StartPoint(0) = 0: StartPoint(1) = 0.5: StartPoint(2) = 0
Set Line(3) = ThisDrawing.ModelSpace.AddArc(StartPoint, 0.5, pi / 2, 3 * pi / 2)
Dim Regions As Variant
Regions = ThisDrawing.ModelSpace.AddRegion(Line)
Accepted solutions (3)
norman.yuan
Have you tried to look up this in VBA document? You do:
1. In VBA editor, open "Object Browser"
2. In the left pane, find and select "AcadRegion"
3. In the right pane, select "Centroid" property
4. Click the "?" button in "Object Browser" window, which would lead you to the VBA document about AcadRegion.Centroid with sample code.
Norman Yuan
Drive CAD With Code
xxaaron
Thanks, the object browser is really useful. I tried to integrate the sample code into my project, but I'm getting the following error: Run-time error 424, object required.  SEE CODE BELOW
pi = 3.xxx-xxxxxxxx
Dim Centroid As Variant
Centroid = Regions.Centroid
MsgBox "The Centroid for the box is " & Centroid(0) & ", " & Centroid(1), , "Centroid Example"
xxaaron
Never mind, I figured it out. It should be Regions = Regions(0).Centroid
