center of polygon area
hello
i need to get the center of area of any polygon.
it should be always inside the polygon
thanks
Like I said: create region from the ploygon and query the Centroid property
of the region.
http://www.acadx.com
Good judgment comes from experience.
Experience comes from bad judgment.
"Jimmy Lopez" wrote in message
news:[email protected]...
> hello
> thanks
Jimmy,
Here is how that is done.
Joe
Public Sub GetCenterOfPolygon()
Dim Entity As AcadEntity
Dim Region As AcadRegion
Dim Polylist(0 To 0) As AcadEntity
Dim Point(0 To 2) As Double
Dim Index As Integer
ThisDrawing.Utility.GetEntity Entity, Point, "Select polygon"
If Entity.ObjectName = "AcDbPolyline" Then
Set Polylist(0) = Entity
ThisDrawing.ModelSpace.AddRegion Polylist
'Find centroid
For Index = 0 To ThisDrawing.ModelSpace.Count - 1
If ThisDrawing.ModelSpace.Item(Index).ObjectName = "AcDbRegion" Then 'Region ?
Set Region = ThisDrawing.ModelSpace.Item(Index)
MsgBox "Centroid X: " & Region.Centroid(0) & vbCrLf & "Centroid Y: " & Region.Centroid(1)
Next Index
'delete region when done
Region.Delete
End Sub
"Frank Oquendo" wrote in message news:[email protected]...
> of the region.
> > hello
> > thanks
hello joe!!
thanks for your help.
Maybe i didn't explain what i need. sometimes my english is not good.
i have a function for getting the centroid of polygon, like the application
you sent me, but i don't create a region.
i just sum x and y coordinates and i get the centroide.
what a really need is, for example in an irregular polygon like an L, the
centroid is outside of it.
i need the centroid always inside. i don't know if i'm talking about
centroid and this is wrong.
do you know Autocad Map?? have you created topologies?? i need the point
like autocad map puts the centroid.
or like arcinfo the same.
thanks very much for your time.
I develope applications in AutoCad and AutoCad Map, working with topologies,
object data, databases etc.
basically GIS, and sometimes i have 50000 polygons for processing.
if i can help you anytime i'm here!!
"Joe Sutphin" wrote in message
> Jimmy,
> Joe
> 'Find centroid
'Region ?
> End If
> Next Index
> End If
> Region.Delete
> End Sub
property
> > of the region.
> > > hello
> > > thanks
Hello Jimmy,
I want to know if you have find a solution for your problem, because I have the seem.
