CANCEL COMMAND DOESN'T WORK
I have searched this discussion group and tried every thing posted to cancel an active command in AutoCad 2002 using VB6 and none of them work. They only work after the command is finished. Can someone please tell me the correct way to STOP an active command say line or circle. I just need to send ESCAPE to the command line. Everything on here works but it only sends ESCAPE after the active command is finished. Please Help.
I'm curious. What technique do you use to start your VBA program while an
AutoCAD command is running?
Regards
Laurie Comerford
wrote in message
news:5855450@discussion.autodesk.com...
I am not using VBA I am using VB6 standalone
