Can you change selected window area without using ZOOM 'W' command?
I'd like to be able to zoom to a specific, pre-defined area using VBA WITHOUT using SendCommand "Zoom W ".
Can it be done and if so, could someone provide an example?
Thanks Jerry
HJohn1
Have you tried Application.Zoom methods?
Hi Jerry,
From the Help file:
object.ZoomWindow LowerLeft, UpperRight
Object
Application
The object this method applies to.
LowerLeft
Variant (three-element array of doubles); input-only
The 3D WCS coordinates specifying the lower-left corner of the window to
display.
UpperRight
The 3D WCS coordinates specifying the upper-right corner of the window
to display.
Remarks
This method applies to the current active viewport (paper space viewport
or model space viewport).
See Also:
Methods and Properties:
ActivePViewport
ActiveViewport
Display
ZoomAll
ZoomCenter
ZoomExtents
ZoomPickWindow
ZoomPrevious
ZoomScaled
ActiveX and VBA Developer's Guide:
"Define a Zoom Window"
"Use Variants in Methods and Properties"
Code such as:
ZoomWindow PtLL, PtUR
requires less typing than SendCommand as well as working better.
Regards
Laurie Comerford
> WITHOUT using SendCommand "Zoom W ". Can it be done and if so, could
> someone provide an example? Thanks Jerry
Thanks... I'll give it a try!
Hi Laurie
Thanks for your help... it does work better except when I'm trying to work in a view other than plan view.
I'm working on a project where the user picks to screen points in order to window and area. The points I'm using are pixels which I then translate into ACAD units using the following code. My problem is that this conversion only works in the plan view. Do you have any thoughts on how I can translate these points to UCS in views other than plan?
My current code:
Dim UpperLeft As POINTAPI
Dim ScreenSize As Variant
Dim ViewCenter As Variant
Dim ScreenCenter As POINTAPI
Dim ViewSize As Variant
Dim PixPerDu As Double
Dim Offset As Point2DDouble
ClientToScreen ThisDrawing.hwnd, UpperLeft
ScreenSize = ThisDrawing.GetVariable("SCREENSIZE")
ViewCenter = ThisDrawing.GetVariable("VIEWCTR")
ScreenCenter.X = UpperLeft.X + ScreenSize(0) / 2
ScreenCenter.Y = UpperLeft.Y + ScreenSize(1) / 2
PixPerDu = ScreenSize(1) / ThisDrawing.GetVariable("VIEWSIZE")
Offset.X = Abs(ScreenCenter.X - X)
Offset.Y = Abs(ScreenCenter.Y - Y)
If ScreenCenter.X < X Then
GetCoordinateFromScreen.X = ViewCenter(0) + (Offset.X / PixPerDu)
Else
GetCoordinateFromScreen.X = ViewCenter(0) - (Offset.X / PixPerDu)
If ScreenCenter.Y > Y Then
GetCoordinateFromScreen.Y = ViewCenter(1) + (Offset.Y / PixPerDu)
Else
GetCoordinateFromScreen.Y = ViewCenter(1) - (Offset.Y / PixPerDu)
GetCoordinateFromScreen.Z = 0
Hi Jerry,
Hope you have found solution for this issue.
If not Try with - object.ZoomCenter Center, Magnify
for Center, input the 3D point (x, y & z value)
for Magify, you can input current view size with your required proportion.
SubuN
