Can fields retrieve attribute values form reinserted block references??
muckmailer
Message 1 of 1
muckmailer
AutoCAD fields can be mapped retrieve an attribute value form a block but if the block reference
is removed form the drawing the field will only give ### values. If a block reference reinserted in the drawing the field values remain ###. Is there a way to get the field to retrieve attribute value from reinserted block reference without remapping the field??
Thank you,
Replies (0)
