Calling up outside functions?
I am currently learning VB other than LISP, and in LISP I have a file called "mysubr.lsp" which has all the subroutines that I use in my other LISP files, rather than retyping the code again. (ie 'dtr' is a function to change from degrees to radians and rather than retyping all the code I type (dtr 90)...this is just a small example of some of the more complicated subroutines I have.) My question is...is there a way in VB to write all my subroutines in one file and call up each routine rather than copying or retyping the code in every new project?
Hi Gary,
If no-one comes up with anything better, what I did was clipboarded the code
from lisp into VBA and then used search and replace for such things as
"(Defun " to "Sub"
I needed to do a fair bit of typing, but it was quicker than starting from
scratch.
You need to ignore the red lines till late in the exercise.
Laurie Comerford
CADApps
www.cadapps.com.au
"GARYNTX" wrote in message
news:f0aa239.-1@WebX.maYIadrTaRb...
I think you misunderstood me. I allready have subroutines/functions in VB, but since I am new to this I don't know the syntax to call up these subroutines other than retyping the subroutines in each project. I would like to put all the functions in one project, module or whatever and have a way to call up a function like I do in LISP.
The subs and functions must all be declared public. Place them all in a
module together, then when you're working on a project and you need one
of your routines, add the module to the project. Call the routines by
placing the module's name in front the routine's name.
ModuleWithRoutines.aFunction
when you type in the module's name and the period the little list should
pop up
you can create a module contaning all your functions and that module insert
in every proyect you have.
i do that. maybe someone has any other option
news:f0aa239.1@WebX.maYIadrTaRb...
There no syntax to 'call up' your subs in VB.
You just place your subs in a module, declare them
as public, and then add the module to the project,
and you can then call them from anywhere in same.
Unlike LISP, you can't "load" a module, you must
include in the project(s) you're going to call it
from.
You can put all of your utility functions in a
separate VBA project and set a reference to that project any time you need
to use the functions it contains.  You set a reference to another VBA
project just like you would set a reference to a DLL.  It isn't a very good
solution though, because it isn't very portable.  A much better solution is
to create an ActiveX DLL, but you will need VB for that.
Chuck
I
every new project?
