CadWorx Information
CadWorx Information
CadWorx Information
Does anyone know how to get access to the Cadworx/Coade (P&ID or PIPE)
information in VBA? I would like to get the Cadworx info off an object and
also manipulate it from VBA.
Any suggestions would be appreciated.
Thank you
Not sure. If it is an ACAD drawing then they may have custom objects or proxies. Do scan of the drawing in VBA.
dim ent as acadentity
dim entname as string
for each ent in thsdrawing.modelspace
entname = ent.objectname
msgbox entname
next
Now if nothing is a proxy or ACADZombie you have a better chance.
They may be stroing data in xdata. If you have the express tolls installed type xdlist at the commandline and enter twice. See ift here is data there. You can also check the drawing sxrecord from VB.
Dave,
Interestingly, no entities exist.
What is "express tolls"?
Jeff
wrote in message news:5555288@discussion.autodesk.com...
msgbox entname
next
Typo, express tools.
No entities>>>????????????
Post a drawing for download so I can take a look. Message was edited by: Discussion Admin
Most, if not all Cadworx entity information is stored within the centerline as XDATA. By using any of the function GetXData, you should be able to retrieve the information that you require. To view what is stored within the Cadworx centerline, simply use the Express/Tools/List Object XData and all will be revealed to you.
