C# .GetXData(string, object, object);
How can I read the data that comes out of .GetXData when using C#. The out is a an object???
foreach (AcadEntity ent in doc.PaperSpace)
      Object xdataType;
      Object xdatavalue;
      ent.GetXData("test", out xdataType, out xdatavalue);
      //how do i read xdatavalue???
Regards
Chris
Norman_Yuan
The output objects (xdataType and xdatavalue) would be either null, or array with at least 1 element (application name). So, you simply cast them as array and loop through them. Something like:
if (xdataType!=null && xdatavalue!=null)
    short[] dTypes=xdataType as short[];
    object[] dValues=xdatavalue as object[];
    for (int i=0; i<dTypes.Length; i++)
        short t=dTypes[i];
        object v=dValues[i];
        switch (t)
            case 1001:
              MessageBox.Show("This is app name: " + v.ToString());
              break;
            case 1000:
              MessageBox.Show("This is text value in XData&colon; " + v.ToString());
              break;
            case ....
Norman Yuan
Drive CAD With Code
Hi Norman, thank you that is just what I was after.
