break line
break line
Message 1 of 11
break line
Need info how to pass the break command with VBA
thank you
"Are you still wasting your time with spam?...
There is a solution!"
Protected by GIANT Company's Spam Inspector
The most powerful anti-spam software available.
http://www.giantcompany.com
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.530 / Virus Database: 325 - Release Date: 10/23/2003
Replies (10)
Message 2 of 11
unless you're talking about using sendcommand, you would implement your own
version of break, getting points and responding accordingly with adding new
entities, deleting old, etc...
(i think)
hth
Mark
"Ramon Triana" wrote in message
news:DF273D149852A4DA11DA01D258EED771@in.WebX.maYIadrTaRb...
Message 3 of 11
No not with sendcommand..i like to place a block with in the line and break
these line
i have these routine done in lisp but i was looking how you do it in VBA.
Thank you
"Mark Propst" wrote in message
news:5651C9AD76ACCD4D53311C241DD0835D@in.WebX.maYIadrTaRb...
own
new
> (i think)
> hth
> Mark
Version: 6.0.530 / Virus Database: 325 - Release Date: 10/22/2003
Message 4 of 11
Hi Ramon,
Select the line
Record the end point coordinates
Change the end coordinates to the location where you want a break
Draw a new line from the break point to the previous end point.
Laurie Comerford
CADApps
www.cadapps.com.au
news:69B76F6BF530B899531484B172C30D05@in.WebX.maYIadrTaRb...
break
> these line
> Thank you
> own
> new
> > (i think)
> > hth
> > Mark
Message 5 of 11
Ok maybe i don't understand but this is what i loking to do
-----------BLOCK---------
LINE BLOCKINS LINE
tHANK yOU
> thank you
Message 6 of 11
There is no Break method.
Modify the original line to form one of the "new" segments, and draw a new
line to make the other new segment.
R. Robert Bell, MCSE
www.AcadX.com
news:57F869DF57139F54C024B535EEC9BB22@in.WebX.maYIadrTaRb...
| LINE BLOCKINS LINE
| tHANK yOU
| > thank you
Message 7 of 11
I'm not at all trying to sound snide or restate the obvious, but it sounds
to me like the thrust of Ramon's question is *how* to calculate the new
endpoints. There've been a few posts on this, and it doesn't look like
there are any simple solutions...
http://groups.google.com/groups?scoring=d&q=trim+block+group:autodesk.autocad.customization.vba
It looks like Ramon could use GetBoundingBox to find approximate break
points of a block if it's not rotated.
Ramon, if you do find some way to use SendCommand to run BREAK or TRIM or
something similar, you'll probably need to use (handent) to input the block
and line objects to the command line. Similar to...
http://groups.google.com/groups?q=handent+group:autodesk.autocad.customization.vba&scoring=d
Sorry I can't be of more help than this, but this doesn't sound too easy.
James
Message 8 of 11
Hi James,
Turn on nearest snap
Pick the first point and the line
Pick the second point
Record the end coordinates of the line
Modify the line to use the picked point as the new end point
Draw a new line using the recorded end point and the second picked point.
No calculations required, easy to program.
Laurie Comerford
CADApps
www.cadapps.com.au
"James Belshan" wrote in message
news:20C326E026D306496E8280EEC6E20DCB@in.WebX.maYIadrTaRb...
block
> James
Message 9 of 11
If you're using AutoCAD 2002 or earlier, you can use the
Break() method of the AcadX Curve object to break *any*
kind of curve entity (e.g., line, arc, polyline, spline,
ellipse, etc), at one or more given points.
http://www.caddzone.com/acadx
Also, the advice of several others regarding how to go about
doing this manually is a bit wrong.
You should *copy* the original line, in order to replicate
its properties, Xdata and so on, rather than 'draw a new line'
as a means of creating the other segment.
AcadXTabs: Document Tabs for AutoCAD
http://www.acadxtabs.com
"Ramon Triana" wrote in message news:57F869DF57139F54C024B535EEC9BB22@in.WebX.maYIadrTaRb...
> LINE BLOCKINS LINE
> tHANK yOU
> > thank you
Message 10 of 11
Shuuuuuuuuuuuuuuut these is a pain in the neck it is so simple in Lisp or
VL..
i finding every day that these VBA w Acad is a bad deal..unless some one
develop a complete function library to manipulate Acad entity to VBA is not
work the effort them.
sorry by my spelling
can program by not spelling 🙂
Thnak You all
> thank you
Message 11 of 11
One solution I use to caculate points is to draw 2 semi-circular arcs with a
center point where your insertion point will be and a radius corresponding
to the block size. Using intersectWith in VBA - you'll easily get the end
points of the new lines. No calculations are necessary.
After you have both intersection points. Generate 2 lines. One from the
StartPoint of the original line to one of the intersection points, and a
second to the 2nd intersection point. Compare the lengths. The short is
the correct line. Redefine the longer lines Startpoint to the End point of
the original line and you're done. Well - except for making sure all the
properties match the original line.
A long winded explaination, but it is actually a simple process.
-George
block
> James
