block rotation
block rotation
block rotation
I would like to prompt the user to select an area with a window and then find all the block entities of a certain type (block name) in the window.
I want to rotate the blocks by various angles
Thank You
Jack
Jackcracker,
this should allow you to select onscreen a group of blocks, it then will
scale each by its insertion point and rotate by 45
Hope this helps
Option Explicit
Sub ad_GetBlocks()
Dim fType(0) As Integer, fData(0)
Dim adBlockSS As AcadSelectionSet
Dim adBlock As AcadBlockReference
Dim i As Integer
On Error Resume Next
Set adBlockSS = ThisDrawing.SelectionSets("adBlockSS")
If Err Then Set adBlockSS = ThisDrawing.SelectionSets.Add("adBlockSS")
adBlockSS.Clear
adBlockSS.SelectOnScreen
fType(0) = 0: fData(0) = "INSERT"
For Each adBlock In adBlockSS
adBlock.ScaleEntity (adBlock.InsertionPoint), 5
adBlock.Rotate (adBlock.InsertionPoint), 45
Next adBlock
Update
adBlockSS.Clear
End Sub
wrote in message news:5790130@discussion.autodesk.com...
Thank You
Jack
Thank you very much. This seems to be what I need
Jack
