block inserting twice
Hello all,
Newbie here trying to do some VBA.
I've got code that does what I want, but it inserts the block twice???? Any suggestions on how to modify the code to only insert the block once at the given location?
Dim blockRefObj As AcadBlockReference
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 567.59: insertionPnt(1) = 929.73: insertionPnt(2) = 0#
Set blockRefObj = ThisDrawing.PaperSpace.InsertBlock(insertionPnt, "C:\Oilfield ACAD-config\Blocks\VERT-COORDS.dwg", 1#, 1#, 1#, 0)
Set BlockRef = ThisDrawing.Blocks("*MODEL_SPACE").InsertBlock(point, Path, 0.1764, 0.1764, 0.1764, 0#)
where
point is ur insertion point
Path is ur path
0.1764 is x , y ,z scale
