Batch Plot to Pdf using Excel Points
I have developed this code but i am not getting values in point1(0 to 1) , point2(0 to 1).Here is the full code.It shows empty when i run.
Option Explicit
Public excelApp As Object
Public wbkObj As Object
Public shtObj As Object
Public point1(0 To 1) As Double, point2(0 To 1) As Double
Sub Example_SetWindowToPlot()
' This example plots a pdf file for each frame as the for function selects each frame.
On Error Resume Next
Dim i As Integer
Dim mRow As Integer
Dim backP As Integer
Set excelApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
Set excelApp = CreateObject("Excel.Application")
If Err <> 0 Then
MsgBox "Could not start Excel", vbExclamation
End
excelApp.Visible = True
Set wbkObj = excelApp.Workbooks.Open(filename:="e:\2.xlsx")
Set shtObj = excelApp.Worksheets(1)
mRow = shtObj.Cells.SpecialCells(xlCellTypeLastCell).Row
'Desactivate background plot
For i = 1 To mRow
' Get first point in window
Set excelApp.shtObj.Range(i, 1).Value = point1(0): Set excelApp.shtObj.Range(i, 2).Value = point1(1)
' Get second point in window
Set excelApp.shtObj.Range(i, 3).Value = point2(0): Set excelApp.shtObj.Range(i, 4).Value = point2(1)
AppActivate ThisDrawing.Application.Caption
backP = ThisDrawing.GetVariable("BACKGROUNDPLOT")
ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
'Select printing config
ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3"
' Send information about window to current layout
ThisDrawing.ActiveLayout.SetWindowToPlot point1, point2
' Read back window information
ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2
' Configure Centerplot to be true
ThisDrawing.ActiveLayout.CenterPlot = True
' Be sure to plot a view, not some other plot style
ThisDrawing.ActiveLayout.PlotType = acWindow
'Name pdf file
Dim plotFileName As String
plotFileName = "C:\Temp\My PDF Plot" & i
'Print pdf
Dim result As Boolean
result = ThisDrawing.Plot.PlotToFile(plotFileName)
Next i
ThisDrawing.SetVariable "BACKGROUNDPLOT", backP
End Sub
norman.yuan
You have these 2 lines of code going backward:
They should be:
point1(0) = excelApp.shtObj.Range(i, 1).Value: point1(1) = excelApp.shtObj.Range(i, 2).Value
point2(0) = excelApp.shtObj.Range(i, 3).Value: point2(1) = excelApp.shtObj.Range(i, 4).Value
Norman Yuan
Drive CAD With Code
