Automatic dataextraction
Hi!
I am trying to create a small VBA code (from excel) that allows me to do a new dataextraction everytime, and create an Excel file (not necessary to be linked with the drawing, i just want the file extracted).
Lets picture the situation:
I have 100 drawings that contains the information more or less in the same shape. I want to run my code once for each drawing.
I have found a solution to an extent:
Sub dataextraction()
AutoCAD.Application.ActiveDocument.SendCommand ("-dataextraction" & vbCr & "C:\Users\alvar\OneDrive\Documentos\pruebaDirectos1.dxe" & vbCr & vbCr)
End Sub
It works, but it creates an excel file with the data of the drawing which the .dxe file comes from.
What i really want is to do an extraction from scratch, but with an specific shape previously set.
Is it possible somehow? it would be very useful because i could skip the dataextraction wizard every time i do the extraction, since i have a great deal of documents.
Thank you very much
Regards
maratovich
What is your ultimate goal?
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
im requested to do several extractions of a great deal of drawings, creating an external Excel File.
Imagine if i do manually:
I will open the dataextraction wizard, i will set everything as i want (filters of objects type, the order of the colmuns of the data in Excel and so on).
What i want is to create a code to call this command and extract everything that is in this drawing in an excel file with the shape that i have set before. also i want to keep the filters , because i just want a part of all the data (for example i just want texts, its cordinates, its content and not so many more info).
I hope that i clarified the issue!
Regards and thanks for your answers.
