Autodesk Sample Code doesn't even work
Tried this and it didn't work. There was a Compile Error: User-defined type not defined
Creating object data tablesStep By Step Sample Code
The following example creates a table of object data: the AutoCAD database entity name, the color, and the layer of the object. It builds object data records from the table and attaches them to objects in the drawing.
Sub tableproc()
Dim amap As AcadMap
Dim ODfdfs As ODFieldDefs
Dim ODfdf As ODFieldDef
Dim ODtb As ODTable
Dim ODrc As ODRecord
Set amap = ThisDrawing.Application. _
GetInterfaceObject("AutoCADMap.Application")
'Create OD Table Definition
Set ODfdfs = amap.Projects(ThisDrawing).MapUtil.NewODFieldDefs
' Add Column Headings and Defaults
Set ODfdf = ODfdfs.Add("Entity", "Entity name", "", 0)
Set ODfdf = ODfdfs.Add("Color", "Object color", acRed, 1)
Set ODfdf = ODfdfs.Add("Layer", "Object layer", "0", 2)
'Ensure Table Does Not Exist
If amap.Projects(ThisDrawing) _
.ODTables.Item("SampleOD") Is Nothing Then
'Register OD Table in the drawing
Set ODtb = amap.Projects(ThisDrawing) _
.ODTables.Add("SampleOD", "Sample Xdata", ODfdfs, True)
'Create OD Record with Defaults
Set ODrc = ODtb.CreateRecord
'Loop Through Entities in Model Space
For Each acadObj In ThisDrawing.ModelSpace
'Fill Records with Entity Data
ODrc.Item(0).Value = acadObj.EntityName
ODrc.Item(1).Value = acadObj.Color
ODrc.Item(2).Value = acadObj.Layer
'Attach Record to Entity
ODrc.AttachTo(acadObj.ObjectID)
Next
Else
'Table Already Exists
MsgBox "Unable to create " & "SampleOD", , _
"Object Data Table Error"
End Sub
Have you set reference to AcadMap/AcadMap200x type library (AmVbApi.tlb)?
You must run this code in AcadMap/Civil, not vanilla Acad. Also, with
different version of AcadMap, the this line of code
Set amap =
ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application")
could be
Set amap =
ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application.2") ''If
you use AcadMap2004
wrote in message news:5495156@discussion.autodesk.com...
type not defined
Sub tableproc()
Dim amap As AcadMap
Dim ODtb As ODTable
Next
Else
End Sub
