AutoCAD Mechanical - GetAllPartReferences causing an error
alain_miltenburg
Message 1 of 1
alain_miltenburg
We have developed an VBA application for generating Part References from Dynamic Blocks. The program works flawlessly when run from the VBA editor. However we are getting the following error when the application is run using -VBARUN:
We have managed to isolate the problem into the code below. Important: Create one Part References and make 2 copies using the copy command before you start.
Option Explicit
Sub Main()
    Dim SymbolBBMgr As McadSymbolBBMgr: Set SymbolBBMgr = ThisDrawing.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
    Dim BOMMgr As McadBOMMgr: Set BOMMgr = SymbolBBMgr.BOMMgr
    Dim AllPartReferences As McadPartReferences
    Set AllPartReferences = BOMMgr.GetAllPartReferences
    AllPartReferences(1).Delete
    AllPartReferences(2).Delete
    ThisDrawing.Application.Update
End Sub
When this code is run from the VBA editor it runs fine. The second GetAllPartReferences results in a collection with one element, as you would expect. Running the code using -VBARUN will result in the aforementioned error message.
What is going on here? Are we missing something? Or is this a bug in the API?
Replies (0)
