AutoCAD crashes
AutoCAD crashes
AutoCAD crashes
Hey everyone,
I added this part to my perfectly working code, and for some reason now it crashes every time I want to run it. Can someone help me?
public sub
'add new layer
On Error Resume Next
    Dim Lay As AcadLayer
    Dim Color As AcadAcCmColor
    Set Color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.22")
    Color.SetRGB 80, 100, 244
    Set Lay = ThisDrawing.Layers.Add("AnkersControle")
    With Lay
        .TrueColor = Color
        .Freeze = False
        .Lineweight = acLnWt009
    End With
On Error GoTo 0
'set new layer as current
ThisDrawing.SendCommand "_-layer _make PCLayer" & vbCr & vbCr
End Sub
grobnik
Hi @Anonymous the procedure hangs on
.TrueColor = Color
 Seems that the color application has some problems.
In order to set the TrueColor correct by cad versione I'm suggesting to apply
Dim color As AcadAcCmColor
    Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(CStr(AcadApplication.Version), 2))
    color.SetRGB 80, 100, 244
Le us know
Hi again @grobnik !
Thank you very much for the speedy answer (again)!
It works perfectly!
