Attributes Utility Concept
Hello all,
I quite few utilities for CAD, however now I'm stuck and need some brainstorming help.
I'd like to be able to edit text in attributes (stamps on each paperspace = different instances with different attributes of the same block, nr. of paper spaces /drawings/ unknown /always differs/) from within a GUI utility.
I.e. when you start a new job, you would set job properties (job name, site name, job number, date) and it would be filled into all stamps for all paper sizes. Other utility would allow to retrieve information and change it in one or multiple stamps.
I can handle all the code around, but I don't know how to start reading/editing the attributes (and do it effectively). Any experience with this issue?
Collin
Colin,
I've used the attached project to change titleblocks and manipulate the attributes. It isn't pretty, but it will show you one method of dealing with attributes.
Joe
