Okay here goes. I've been working with vba for years and think it is a great system but I am new to Autocad and customizing it via VBA.
I have a drawing(s) that have a series of blocks. These blocks (approximately 13 of them per drawing) contain drawing numbers, revision levels and so forth. I need to update the value of the revision level, or "tag", in each block. Is it possible to write a sub that would update all of them at once instead of having to eattedit each individual block? Is it even possible or am I trying to divide by zero? I don't want to waste anymore time on this if what I'm asking for is pie in the sky. If it is possible could anyone point me in the right direction?
I've been looking all over the web for more than a week now and I'm close to banging my head against a wall. There's a lot of material out there but it's either cryptic in the details or overwhelmingly complex. So much so that I can't pick through it to get what I'm after.
Thanks for any help you may be able to give me.
