Array of Controls...
In VB6 I can create an array of controls, like a textbox(0 to 6), but I cant
do that on a vba form...
If I have a group of similar controls (textbox1, textbox2, textbox3) how can
I loop through them
with this type of code:
for x = 1 to 3
var = userform1.textbox(x).value
next
Rodney
Hi Rodney
Use the Frame control and place the other controls inside. Then you can loop
through the controls like you want.
Cheers
Juerg Menzi
MENZI ENGINEERING GmbH, Switzerland
http://www.menziengineering.ch
> I loop through them
> for x = 1 to 3
> next
> Rodney
The controls are in a frame... What is the code to loop through them...
My sample code does not work...
Rodney
"Jürg Menzi" wrote in message
news:3B7D154D.38D7825D@bluewin.ch...
> Hi Rodney
loop
> Cheers
> Juerg Menzi
cant
can
> > I loop through them
> > for x = 1 to 3
> > next
> > Rodney
Hi Rodney
For x = 0 to (NumberOfControls -1)
Var = FrameName(x).Value
Next x
That's it...
Cheers
Juerg Menzi
How do I know which control I am getting with the X index?
Rodney
news:3B7D3C41.19893C06@bluewin.ch...
> Hi Rodney
> Next x
> That's it...
> Cheers
> Juerg Menzi
Randal Rath at VbDesign has a routine that works by assigning the 'index number'
to the control's tag property. Then you can loop through the controls and check
the 'tag' value to know which control it is working on. Silly that vba does not
support control arrays.
Go to his web site and look around, the routine is there somewhere.
Tom
> I loop through them
> for x = 1 to 3
> next
> Rodney
