arranging circles
arranging circles
arranging circles
For one of my appication i need to arrange small circles in a big circle.
the small circle dia and pitch are constant.
the inputs would be
1)small circle dia
2) type of pitch t = triangular or rectangular
3)pitch
4) number of circles.
please refer attached file for your reference
the aim of this is to find the minimum dia of the big circle to accomadate small circles.
can anyone please provide me a lisp or vba program to do this
thanks in advance
regards
Rayalla
I am not a math because of you need to check all
extensively
Change small radius
Hth
Option Explicit
Sub holes()
Dim s As Double, b As Double, st As Double
Dim mx1 As Double, mx2 As Double
Dim n As Integer, c As Integer
Dim oEnt As AcadEntity, rEnt As AcadEntity
Dim cent(2) As Double, npt(2) As Double
Dim upt(2) As Double, spt(2) As Double
Dim varpt As Variant, xpt As Variant, hpt As Variant
Dim bc As AcadCircle, sc As AcadCircle
Dim retObj1 As Variant, retObj2 As Variant
Dim ans As String
Dim pi As Double
pi = Atn(1) * 4
s = 20#
ans = InputBox("Enter arrange mode" & _
vbNewLine & "Rectangular or Polar" & _
vbNewLine & "case-nonsensitive (R or P) :", "Arrange mode", "R")
varpt = ThisDrawing.Utility.GetPoint(, "Pick center")
cent(0) = CDbl(varpt(0))
cent(1) = CDbl(varpt(1))
cent(2) = CDbl(varpt(2))
If UCase(ans) = "R" Then
b = 480#
st = 70#
c = (Fix(b / st) + 1) * 2
mx1 = c * st
npt(0) = cent(0) - mx1 / 2
npt(1) = cent(1) - mx1 / 2
npt(2) = cent(2)
upt(0) = cent(0) + mx1 / 2
upt(1) = cent(1) + mx1 / 2
upt(2) = cent(2)
ZoomWindow npt, upt
Set bc = ThisDrawing.ModelSpace.AddCircle(cent, b)
Set sc = ThisDrawing.ModelSpace.AddCircle(npt, s)
retObj1 = sc.ArrayRectangular(c, c, 1, st, st, 0)
For n = 0 To UBound(retObj1)
Set oEnt = retObj1(n)
xpt = oEnt.Center
If Distance(xpt, varpt) >= b - s Then
oEnt.Delete
Next
sc.Delete
ElseIf UCase(ans) = "P" Then
b = 450#
st = 76#
Dim xi As Double, yi As Double
Dim c1 As Integer, c2 As Integer
xi = Sqr(st ^ 2 - (st / 2) ^ 2)
yi = st / 2
c1 = (Fix(b / xi * 2) + 1) * 2
mx1 = c1 * xi * 2
c2 = (Fix((b - yi) / st) + 1) * 2
mx2 = c2 * st - st
npt(1) = cent(1) - mx2 / 2
npt(2) = cent(2)
upt(1) = cent(1) + mx2 / 2
upt(2) = cent(2)
ZoomWindow npt, upt
retObj1 = sc.ArrayRectangular(c2, c1, 1, st, xi * 2, 0)
xpt = oEnt.Center
oEnt.Delete
Next
sc.Delete
spt(0) = npt(0) + xi
spt(1) = npt(1) + st / 2
spt(2) = npt(2)
Set sc = ThisDrawing.ModelSpace.AddCircle(spt, s)
retObj2 = sc.ArrayRectangular(c2, c1, 1, st, xi * 2, 0)
For n = 0 To UBound(retObj2)
Set oEnt = retObj2(n)
xpt = oEnt.Center
oEnt.Delete
Next
sc.Delete
Else
MsgBox "Wrong input"
Exit Sub
ZoomAll
ThisDrawing.Regen acActiveViewport
End Sub
Public Function Distance(fPoint As Variant, sPoint As Variant) As Double
Dim x1, x2 As Double
Dim y1, y2 As Double
Dim z1, z2 As Double
Dim cDist As Double
x1 = fPoint(0): y1 = fPoint(1): z1 = fPoint(2)
x2 = sPoint(0): y2 = sPoint(1): z2 = sPoint(2)
cDist = Sqr(((x2 - x1) ^ 2) + ((y2 - y1) ^ 2) + ((z2 - z1) ^ 2))
Distance = cDist
End Function
Fatty
~'J'~ Message was edited by: Fatty
Dear Fatty,
When i appload the code which you provided Autocad says error :Bad function : 2
could you help me out in this regard.
bye
Rayalla
Hi Rayalla
I have copied right now this code which
I apploaded here and this works nice for me
I used A2005 only
I don't know where you got error message, sorry
Fatty
~'J'~
Hi Fatty,
i am using A2002 for this does this code need to be changed???
rayalla
Hi Rayalla
You need in VBEditior in the menu Tools->References to
change reference on your current AutoCAD 2002 Type Library
and nothing else I hope
You'll see there this line with "MISSED" word
~'J'~
