Arc
Arc
Arc
I want to draw arc using VBA. For this required input is center, radius, start and end angles.
But in my case I have Start point,end point and radius. I can draw arc using theses parameters in Autocad, but don't know how i can draw arc in VBA using these given parameters.
Does any wany suggest me way to do so ??
regards
Some basic math may help here. Unless one of the points is tangential and you also specify CW/CCW order of the points, there are mutiple arcs that can be drawn with start/end point and the radius. Try it in AutoCAD and you will see what I mean. -- egc - Sudden Supernumerary For Sale Cheap. Dick Cheney's Best Seller "Obtaining Government Contracts - You Too Can Make a Killing" ------------------------------------------------------------------------ egc's Profile: http://www.vbdesign.net/expresso/member.php?action=getinfo&userid=1023 View this thread: http://www.vbdesign.net/expresso/showthread.php?threadid=59852
hello, thanks for reply
my arc is drawn in counter clock wise and I could not find multiple arcs in Vba. Can you give me more hints about it?
details
This might help you. (No error checking at all): Public myarc As AcadArc Public Const pi As Double = 3.14159265358979 Public Sub DrawArcSER(sp As Variant, ep As Variant, rad As Double) Dim h As Double Dim b As Double Dim ls As Double Dim mp As Variant Dim cp As Variant Dim sa As Double Dim ea As Double b = ThisDrawing.Utility.AngleFromXAxis(sp, ep) ls = Sqr((sp(0) - ep(0)) ^ 2 + (sp(1) - ep(1)) ^ 2) mp = ThisDrawing.Utility.PolarPoint(sp, b, ls / 2#) h = Sqr(rad ^ 2 - (ls / 2#) ^ 2) cp = ThisDrawing.Utility.PolarPoint(mp, b + (pi / 2#), h) sa = ThisDrawing.Utility.AngleFromXAxis(cp, sp) ea = ThisDrawing.Utility.AngleFromXAxis(cp, ep) Set myarc = ThisDrawing.ModelSpace.AddArc(cp, rad, sa, ea) End Sub 'example of how to use the DrawArcSER sub Sub DARC() Dim spoint As Variant Dim epoint As Variant Dim radius As Double spoint = ThisDrawing.Utility.GetPoint(, "Arc Start Point:") epoint = ThisDrawing.Utility.GetPoint(spoint, "Arc End Point:") radius = ThisDrawing.Utility.GetDistance(spoint, "Arc Radius:") Call DrawArcSER(spoint, epoint, radius) End Sub -- Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica (sorry, phony e-mail, SPAM made me do it) "Kumar" wrote in message news:8130509.1077988642819.JavaMail.jive@jiveforum1.autodesk.com... > I want to draw arc using VBA. For this required input is center, radius, start and end angles. > > But in my case I have Start point,end point and radius. I can draw arc using theses parameters in Autocad, but don't know how i can draw arc in VBA using these given parameters. > > Does any wany suggest me way to do so ?? > > regards
If Jorge's example [nice one:)] doesn't help, check out http://vbdesign.net. ___________________________ Mike Tuersley CADalyst's AutoCAD Clinic Rand IMAGINiT Technologies
