arc chord lenght
arc chord lenght
arc chord lenght
Does anybody can help me?, I need to dimensioning the lenght of an arc instead of the angle.
Hi Daniel,
Using the following functions:
Public Function Radians(Degrees As Double) As Double
Radians = Degrees / 180 * 3.141592654
End Function
Private Function Degrees(Radians As Double) As Double
Degrees = Radians / 3.141592654 * 180
End Function
Where arc is a variable set to the arc in question(a true acadarc not a
polyline), it should be something to the effect of:
chord_length = 2(sin(arc.angle/2))/arc.radius)
Double check my parenthesis, but all in all its the sin of 1/2 the arc
angle divided by the arc radius times 2.
-Josh
Oops, instead of arc.angle use angle:
angle = degrees(radians(360) + arc.endangle - arc.startangle)
My head was in the math not the code, sorry.
-Josh
Minkwitz Design wrote:
> Hi Daniel,
> End Function
> End Function
> -Josh
Create a Dim3PointAngular object and add this line right after to replace
the angle with the arc length:
DimObj.TextOverride = ThisDrawing.Utility.RealToString(ArcObj.ArcLength,
acArchitectural, 4)
-- Walter -- http://www.ActiveDwg.com
"daniel-vazquez" wrote in message
news:f0d31f5.-1@WebX.maYIadrTaRb...
