Ak2 VBA help for Extrusion
Hi:
Can some one look in to following code and tell me why am I getting error?
All am trying to do is add a polyline, select the last added item in
selection set, make a region out of selection set (This is where I get
error) and finally extrude the region.
The objective is to extrude LWPolyline. If you have any other suggestions
to accomplish the same, please let me know. Thanks in advance.
Sub aaaa()
Dim plineObj As AcadPolyline
Dim points(0 To 14) As Double
Dim ssetObj As AcadSelectionSet
Dim ssetcoll As AcadSelectionSets
Dim region_a(0 To 1) As AcadRegion
Dim solid1 As Acad3DSolid
points(0) = 0: points(1) = 0: points(2) = 0
points(3) = 0: points(4) = 1: points(5) = 0
points(6) = 1: points(7) = 1: points(8) = 0
points(9) = 1: points(10) = 0: points(11) = 0
points(12) = 0: points(13) = 0: points(14) = 0
Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
Set ssetcoll = ThisDrawing.SelectionSets
Name1 = "m1"
' this will have to change everytime you rerun during debugging
Set ssetObj = ssetcoll.Add(Name1)
ssetObj.Select acSelectionSetLast
region_a(0) = ssetObj.Item("0")
Set solid1 = ThisDrawing.ModelSpace.AddExtrudedSolid(region_a(0), 100,
0)
ssetObj.Delete
End Sub
In this case, there is no need for a selection set. You already have the object
you want to extrude, just pass it to the array. Also, you pass the entire array,
not just a single element of it, to the AddExtrudeSolid method:
Set region_a(0) = plineObj
Set solid1 = ThisDrawing.ModelSpace.AddExtrudedSolid(region_a, 100, 0)
HTH
http://www.acadx.com
"Thank goodness! I thought my boots were cracked."
"Vpatel" wrote in message
news:BF95CCBB29A648730F5B0ADF06ADE313@in.WebX.maYIadrTaRb...
> Hi:
If I try your suggested solution, I get error (type mismatch). Following is
the code after taking your comments in to account. Please look and see if
you can help. Thanks.
Viral
Sub add_ucs2()
Dim region_a As AcadRegion
Set region_a = plineObj
ssetObj.Delete
End Sub
"Frank Oquendo" wrote in message
news:CDFFF991D1662297FA07812B29641D62@in.WebX.maYIadrTaRb...
object
array,
> HTH
> > Hi:
error?
suggestions
Region_A is supposed to be an array of AcadEntity or any descendant
thereof:
Dim region_a(0) As AcadEntity
"V Patel" wrote in message
news:6FA928DFB9741D7FEBF4369A18DC1344@in.WebX.maYIadrTaRb...
Following is
see if
> Viral
> Sub add_ucs2()
100, 0)
> ssetObj.Delete
> End Sub
have the
> object
entire
> array,
100, 0)
> > HTH
> > > Hi:
getting
> error?
item in
I get
> suggestions
If region_a(0) is defined as AcadEntity, the Set region_a(0) = plineObj
works fine but in the following statement "Type mismatch" error is produced.
It appears that the AddExctrudSolid needs Region not AcadEntity.
Set solid1 = ThisDrawing.ModelSpace.AddExtrudedSolid(region_a(0),100, 0)
Thanks or help.
V Patel
news:441E63FAC5E3DD7E60A102D65C89E53B@in.WebX.maYIadrTaRb...
> thereof:
> Following is
> see if
> > Viral
> > Sub add_ucs2()
> 100, 0)
> > ssetObj.Delete
> > End Sub
> have the
> > object
> entire
> > array,
> 100, 0)
> > > HTH
> > > > Hi:
> getting
> > error?
> item in
> I get
> > suggestions
In that case, have you made a region from your polyline?
news:53AA0B04B486EAF913108E95675ACD63@in.WebX.maYIadrTaRb...
> Thanks or help.
> V Patel
No from the dim statement, I just made AcadEntity and not AcadRegion. That
is the reason why "Type mismatch" error is produced.
The question is how one can make region from the polyline that was just
drawn.
Thanks again for help.
news:BD841B654AEF483EACEFB976CC4D5848@in.WebX.maYIadrTaRb...
produced.
> > Thanks or help.
> > V Patel
