After I make hatch, I want my layer back
Hello there,
what is wrong with this command line ...... someone can edit it (to work)
....? (ACAD 2000 -ger-)
(setq layer (getvar "clayer"));(setvar "clayer" "schraff");(command
("-gschraff" "ei" "ansi31" "1" "0");(setvar "clayer" "layer")
The problem:
I have one aktive Layer (f.e. Layer "Help")
Then I want to draw hatch. (the complete command line at the top should
start)
I that case, AutoCAD should change the actual Layer to "Schraff" (special
layer for hatch)
After I make my hatch, I want my layer (before doing hatch) back, as actual
(in that case "Help")
The problem is that AutoCAD don`t wait untill I have done my hatch .....
I have to make a "pause" or a "wait for command end" ......
But with one Pause in the command line I can do one hatch ...(Acad should
wait for user exit command !!)
How can I do this ......... oh please, help me
Thanks a lot , .................. Matthew
Try removing the double-quotes around the variable named "layer", (setvar
"clayer" layer) instead of (setvar "clayer" "layer").
John Goodfellow
irtf'nm
use 'microtouch' in address to email
"Matthew $" wrote in message
news:6D3E6DCCB8AA9F2C9BFE4B188894587B@in.WebX.maYIadrTaRb...
> Hello there,
> The problem:
> start)
> layer for hatch)
actual
I have tried to paste these lines after a toolbutton made in Autocad but no results yet.
Always get the same message can anyone help?
Command: (setq layer (getvar "clayer"))
"arceren"
Command: (setvar "clayer" arceren)
; error: AutoCAD variable setting rejected: "clayer" nil
Command: (command("-hatch" "p" "ansi31" "2" "0")
(_> (setvar "clayer" "layer") *Cancel*
; error: Function cancelled
thanks in advance!
Cootn
You are in the wrong group.
But your issue is the bad variable name arceren and the bad quotes around
the correct variable name layer.
R. Robert Bell
wrote in message news:5523356@discussion.autodesk.com...
results yet.
"arceren"
thanks in advance!
Cootn
