ADO help
ADO help
ADO help
this isn't related to autocad but this group is the only reliable vb source
i have.
why do i get an eof error in this code?
Do Until People.EOF Or People!Client = lstPeople.List(lstPeople.ListIndex)
People.MoveNext
Loop
shouldn't it just drop out if eof = true? i've checked the value of
people.eof and it is true but it won't drop out.
please help,
Rob
What happens if you remove the second part of your test?
Good judgment comes from experience.
Experience comes from bad judgment.
http://www.acadx.com
"Rob Tomson" wrote in message
news:476F8B4CE9E69CD4AF82A43BF4A02491@in.WebX.maYIadrTaRb...
source
> i have.
> People.MoveNext
> Loop
> please help,
> Rob
i can't remove the second part....what i have is a list box of clients and
when i click on the client then it pulls info from a database and popluates
text boxes, etc. if i remove the eof test then i'll get an error when i
create a new entry in the listbox
"Frank Oquendo" wrote in message
news:AE21266E4291C27E96DCC02EF42A2B57@in.WebX.maYIadrTaRb...
> source
> > i have.
> > People.MoveNext
> > Loop
> > please help,
> > Rob
If you're retrieving information on the selected client, why use a
loop at all? A properly formed SQL statement will allow you to select
just the one record. This will be a lot quicker and easier to debug:
' Let's assume you already have a connection 'cn'
Dim rs As ADODB.Recordset
Dim strSQL As String
strSQL = "SELECT * FROM ClientTable WHERE ClientID = " &
List1.ItemData(List1.ListIndex)
rs.Open strSQL, cn, adOpenForwardOnly, adLockReadOnly
If Not (rs.BOF And rs.EOF) Then
' You have a record, do your thing
news:678145EF8D38F9307CB1EF9563D31D20@in.WebX.maYIadrTaRb...
clients and
popluates
when i
thanks! i'll try that.
news:2651B20EA6F660A7FA545BC053E54954@in.WebX.maYIadrTaRb...
> End If
> clients and
> popluates
> when i
