ADO and VBA - Problems
Hello
I'm triyng to use an ADO control with an access database in a vba proyect,
then i fill a datagrid with the database..
There's no problem inserting the control into the form and configuring it,
but when i execute the program no data is loaded into the data grid.
Does anyone know why???
Show the code or the connect string your using with the ADO control.
Veign
www.veign.com
NEW ActiveX Control - Jeweled Style Buttons
www.veign.com/download_activex.html#jwldbutn
Code Samples & Sample Projects
http://www.veign.com/information/application/info_app.html
Submit Your Best Code (you keep the rights)
http://www.veign.com/information/application/code_submit.html
"Jose Luis" wrote in message
news:[email protected]...
> Hello
Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Archivos de
programa\Wilo\Wilo-Select Classic\Data\vsSpaix.mdb;Persist Security
Info=False
I've a problem when i set the datasource property of the datagrid, when i
compile it, it shows the error: "No se encontro el metodo o el dato
miembro", i'll traslate it for you: "I cant find the method or data member",
is this because this control in AutoCAD have less properties than in VB
Studio????..
Thank you
"Veign" escribió en el mensaje
> Veign
> www.veign.com
> > Hello
proyect,
it,
Well, they don't have less properties, but they have less properties shown in the "property window". That means that u have to connect it to the database manually (by coding) instead of just changing the properties in the property box (which is what u do in VB).
I had the same problem and Veign led me to this site:
http://www.freevbcode.com/ShowCode.Asp?ID=1728
which contained the code for doing so. It worked perfect for me. So why don't u give it a try....
Just notice that there is a couple of typing mistakes. Double check all the names.
(I think there is a oConn instead of Conn or something like that)
Good luck
