AddLeader question
AddLeader question
Message 1 of 9
AddLeader question
Why is it that if you use Qleader in autocad it will use your current dimension style as the means to draw your leader, and when you use the addleader method it wants you to specify everything. Is there something i'm missing so that you can get the Mtext and LeaderObject to use the same dimension style as in the qleader.
Replies (8)
Message 2 of 9
AddLeader doesn't add a QLeader but rather the Dimension mode's Leader.
R. Robert Bell
wrote in message news:5413807@discussion.autodesk.com...
Message 3 of 9
So what are my options?
Message 4 of 9
If you want a QLeader, Visual LISP. I do not know if .NET will give you
this.
R. Robert Bell
wrote in message news:5414568@discussion.autodesk.com...
Message 5 of 9
Well is there a way i can read a variable of a current dimension style so that i can set the variables within the add leader method?
Message 6 of 9
Of course.
Sub Test()
With ThisDrawing.ModelSpace
Dim myTextPt(0 To 2) As Double
myTextPt(0) = 1.25: myTextPt(1) = 1: myTextPt(2) = 0
Dim myText As AcadMText
Set myText = .AddMText(myTextPt, 1, "123")
myText.Height = ThisDrawing.GetVariable("DimTxt")
myText.StyleName = ThisDrawing.GetVariable("DimTxSty")
myText.AttachmentPoint = acAttachmentPointMiddleLeft
myText.InsertionPoint = myTextPt
Dim myPts(0 To 8) As Double
myPts(0) = 0: myPts(1) = 0: myPts(2) = 0
myPts(3) = 1: myPts(4) = 1: myPts(5) = 0
myPts(6) = myTextPt(0): myPts(7) = myTextPt(1): myPts(8) = myTextPt(2)
.AddLeader myPts, myText, acLineWithArrow
End With
End Sub
R. Robert Bell
wrote in message news:5415117@discussion.autodesk.com...
Message 7 of 9
If i am understanding correctly, the code you gave me the variable your getting the value of would have to be the current dimension style. Is there a way to specify which dimension style to get the variable from?
Message 8 of 9
Here's an example....
Standard = Current
Style1
Style2
Style3 <--- Get Variable from this DIM Style
Message 9 of 9
Not without making it current. And in your OP you did say "use your current
dimension style".
R. Robert Bell
wrote in message news:5416530@discussion.autodesk.com...
Standard = Current
Style1
Style2
