Adding text as selected Object Layer name
jyan2000
jyan2000
How do I add text with selected obeject Layer name?
exp:
Layer name : Wall Partition_150mm
DText : "Wall Partition_150mm"
Regards
Victor
Alfred.NESWADBA
are you using VB.NET or VBA?
Can you show the code you have currently so we so where you have the problems and so where to start?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jyan2000
Hello Alfred,
I've found this code, but it doesn’t work. I'd like to edit specific descriptions with TEXT, such as TEXT height (50), TEXT Position (0, 0, 0), TEXT Layer same as Selected Object, TEXT Justify ( M ).
Best regards
Victor
(defun rjp-addtext (ins hgt text / doc x)
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(vla-addText
(if (= (getvar 'cvport) 1)
(vla-get-paperspace doc)
(vla-get-modelspace doc)
text
(vlax-3d-point ins)
(* (getvar 'dimscale) hgt)
(defun c:test (/ index ss obj lyr ept spt mpt)
(setq index -1)
(if (setq ss (ssget "x" '((0 . "PLINE"))))
(progn
(while (< (setq index (1+ index)) (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss index))
lyr (vla-get-layer obj)
ept (vlax-get obj 'endpoint)
spt (vlax-get obj 'startpoint)
mpt (polar ept (angle ept spt) (/ (distance ept spt) 2.0))
(rjp-addtext mpt 1 lyr)
(princ)
(princ)
