Adding New TextStyle
HI,
I am having a problem adding a textstyle in vba. What I am doing is looping through several different textstyles to add them dynamically. When I do this the routine fails with the error "Run-time erro '-2145320949 (8021000b)': Calling method SetObjectId of interface IAcadBaseObject failed". What I have found out is that when I add the textstyle using a variable for my name it fails, if i actually type the name in it works. Here is a code snippet of each.
DOES NOT WORK
For intI = 0 To 1
Dim StyleHt As Double, StyleWF As Double, StyleOA As Double
tempAry = Split(strStyleAry(intI), ",")
Dim strStyleName As String
strStyleName = tempAry(0)
Dim objTextStyle As AcadTextStyle
Set objTextStyle = .TextStyles.Add(strStyleName)
Set TextStyleObject = Nothing
Next
WORKS
Set objTextStyle = .TextStyles.Add("TESTSTYLE")
Please help, I cannot figure out why this is happening....
Mike
First thing I'd check is that the line:
Is returning what you think it is.
wrote in message news:5052540@discussion.autodesk.com...
HI,
i have checked that....it does return exactly what it should. basically, whatever i hardcode into the section of code that works, is being returned into that variable.
Could you post the rest of the code? I cannot duplicate the error when I
recreate your code.
Jeff
wrote in message news:5052798@discussion.autodesk.com...
into that variable.
Well, here's the code I tried and it works just fine......
Sub textstyleTEST()
Dim intI As Integer
Dim intJ As Integer
Dim tempAry As Variant
Dim strStyleAry(1) As String
strStyleAry(0) = "Styl1,Styl2"
strStyleAry(1) = "Styl3,Styl4,SuperDuperStyle"
For intI = 0 To 1
For intJ = 0 To UBound(tempAry)
strStyleName = tempAry(intJ)
Set objTextStyle = ThisDrawing.TextStyles.Add(strStyleName)
Debug.Print objTextStyle.Name
Set objTextStyle = Nothing
Next
Next
End Sub
"Jeff Mishler" wrote in message
news:5052849@discussion.autodesk.com...
recreate your code.
Jeff
