Adding dimensions to selection sets.
Hi there,
Could someone help point me the right direction please.
I am trying to select all the dimension's and text within a drawing so that
I can update the dimscale.
I am presuming that I need to build a selection set, but I cannot fatham how
to filter just the dimensions and text. !
Dave
hi dave
within vb/a you have to build 2 (or more) selections, one for "DIMENSION",
one for "TEXT" (and/or "MTEXT")
regards, alfred
___________________________________________________________
Alfred Neswadba
Ingenieur Studio HOLLAUS
A-3100 St.Poelten, Brandstroemg. 6..... +43 699 21807303
Internet ................................ www.hollaus.at
E-Mail ...................... alfred.neswadba@hollaus.at
"Dave Wilkinson" schrieb im Newsbeitrag
news:D67F21A123B706ACB7AB4E7513DB9420@in.WebX.maYIadrTaRb...
> Hi there,
that
how
> Thanks
> Dave
but how do I filter just the dimensions ?
I have used a filter previously to get block information using DXFdata and
DXFcode, but am not sure how to go about the dimensions ????
Dave
"Alfred Neswadba" wrote in message
news:51F924AFF06F045B2A7C419EA7C22158@in.WebX.maYIadrTaRb...
> hi dave
> regards, alfred
> Alfred Neswadba
> > Hi there,
> that
> how
> > Thanks
> > Dave
Option Explicit
Dim acad_doc As AcadDocument
Public Sub mytest()
Dim t_sset As AcadSelectionSet
Dim dxfcode(0) As Integer
Dim dxfvalue(0) As Variant
On Error GoTo FUNC_EXIT
Set acad_doc = ThisDrawing 'if you are not in vba, then replace
thisdrawing with your document
'create selection set in drawing
On Error Resume Next
Set t_sset = acad_doc.SelectionSets.Add("my_sset")
If Err Then
Err.Clear
Set t_sset = acad_doc.SelectionSets("my_sset")
t_sset.Clear
'now get entities
dxfcode(0) = 0
dxfvalue(0) = "DIMENSION" 'that is the dxfcode for dimenstions
t_sset.Select acSelectionSetAll, , , dxfcode, dxfvalue
MsgBox t_sset.Count
FUNC_EXIT:
If Err Then MsgBox Err.Number & " / " & Err.Description
acad_doc.SelectionSets("my_sset").Delete
Set t_sset = Nothing
Set acad_doc = Nothing
Err.Clear
On Error GoTo 0
End Sub
regards, alfred
Alfred Neswadba
news:FE4EAA502D38EE150F4749CA4A97DAC1@in.WebX.maYIadrTaRb...
> Thanks
> Dave
> > hi dave
"DIMENSION",
> > regards, alfred
> > Alfred Neswadba
> > > Hi there,
> > that
fatham
> > how
> > > Thanks
> > > Dave
Thanks Alfred
I have found the dxf group codes in the help after looking for "DIMENSION"
as you have shown in your code.
Thanks once again for putting on the right track
Dave
news:015E1D8969FE81A9F98D6AED36223805@in.WebX.maYIadrTaRb...
> Option Explicit
> Public Sub mytest()
replace
> If Err Then
> Err.Clear
> t_sset.Clear
> End If
> 'now get entities
> dxfcode(0) = 0
> MsgBox t_sset.Count
> FUNC_EXIT:
> Err.Clear
> On Error GoTo 0
> End Sub
> regards, alfred
> Alfred Neswadba
nd
> > Thanks
> > Dave
> > > hi dave
> "DIMENSION",
> > > regards, alfred
> > > Alfred Neswadba
> > > > Hi there,
so
> > > that
> fatham
> > > how
> > > > Thanks
> > > > Dave
A suggestion: you create a selectionset with dimensions AND text (or also
MTEXT) with this:
dxfcode(0) = 0
dxfvalue(0) = "DIMENSION,TEXT,MTEXT"
Good luck,
Henk
