adding controls dynamically
Message 1 of 8
I'm using acad 2002 and I'm trying to add some controls dynamically. I have
a form that has a multipage control on it. This control has pages added to
it dynamically based on the number of drawings that are open. (this part
I've got working). Where I'm having my problem is creating controls that are
needed on this new page. I'm trying to create another multipage control on
the new page which will have two pages with a listview control on each of
the subpages.
If I could see an example of how any type of control is added dynamically,
it would give me enough to figure it out.
TIA
Brent
Replies (7)
Message 2 of 8
You would do it the same way that you are adding tab pages, except that you
add the new controls to the page's Controls collection.
Ed
"Brent" wrote in message
news:126E3CC01C0F3E04CF9518FD10EAAA2C@in.WebX.maYIadrTaRb...
have
are
> the subpages.
> TIA
> Brent
Message 3 of 8
I keep getting the error "Invalid Class String" when I try to create a
control.
Dim myCtrl as Control
Set myCtrl = pgDwgX.Controls.Add("MSFORMS.textbox.1", "mytextbox",true)
"Ed Jobe" wrote in message
news:804F92752C0E2A068CE68ED8EB79E239@in.WebX.maYIadrTaRb...
you
> Ed
> have
to
> are
on
of
> > the subpages.
dynamically,
> > TIA
> > Brent
Message 4 of 8
Try "Forms.TextBox.1".
Ed
news:7C232D0585DD906B6AEE2530505A867A@in.WebX.maYIadrTaRb...
> control.
> you
> > Ed
> > have
added
> to
part
that
> > are
control
> on
each
> of
> > > the subpages.
> dynamically,
> > > TIA
> > > Brent
Message 5 of 8
Thanks Ed - that finally worked.
I came across the "MSForms.Textbox.1" by scouring through so much stuff. In
the future, where can I find what is the correct syntax to use in situations
like this?
news:78C2E5ED736460F2143D198FA7577985@in.WebX.maYIadrTaRb...
> Ed
> > control.
that
> > you
> > > Ed
I
> > > have
> added
> > to
> part
> that
> > > are
> control
> > on
> each
> > of
> > > > the subpages.
> > dynamically,
> > > > TIA
> > > > Brent
Message 6 of 8
When in vbaide, Help>Contents>Microsoft Forms Reference>Microsoft Forms
Object Model Reference>Methods>Add
Ed
news:11F4513B381B384F362DA1404A3C7E7A@in.WebX.maYIadrTaRb...
In
situations
> like this?
> > Ed
> > > control.
"mytextbox",true)
> that
> > > you
> > > > Ed
dynamically.
> I
> > > > have
> > added
> > > to
(this
> > part
controls
> > that
> > > > are
> > control
> > > on
> > each
> > > of
> > > > > the subpages.
> > > dynamically,
> > > > > TIA
> > > > > Brent
Message 7 of 8
Thanks for the reference information. In trying to follow the syntax, I'm
running into the same type of error when I try to
add a listview control. The control is referenced in vba and for the progid
used in the add process, I've tried
"MSComctllib.listview.1"
"comctllib.listview.1"
"comctl.listview.1" etc
and I'm still getting invalid class string - sorry to bother you again. How
does one find what progid should be used. I would have thought it would be
listed in the object browser which lists it as MSComctlLib but that doesn't
work.
TIA - brent
news:B9C393F71E65EB34B9EBA0D514166796@in.WebX.maYIadrTaRb...
> Ed
> In
> situations
> > like this?
> > > Ed
a
> > > > control.
> "mytextbox",true)
> > that
> > > > you
> > > > > Ed
> dynamically.
> > I
> > > > > have
pages
> > > added
> > > > to
> (this
> > > part
> controls
> > > that
> > > > > are
> > > control
> > > > on
on
> > > each
> > > > of
> > > > > > the subpages.
> > > > dynamically,
> > > > > > TIA
> > > > > > Brent
Message 8 of 8
Another approach might be to create the form with as many multipage tabs as
you think you'll need, with the controls, then at runtime set the "visible"
property to false for the pages you don't need.
have
are
> the subpages.
> TIA
> Brent
