Adding a item with it's ObjectID to a selection set.
I was trying to add an entity to a selection set. I'm hacking
up your CAO example so I have its ObjectID.
'***this is what have so far:
Dim pick As
AcadSelectionSet
With ThisDrawing.SelectionSets
    Do
While .Count > 0
.Item(0).Delete
    Loop
End With
Set pick =
ThisDrawing.SelectionSets.Add("omar")
pick.Clear
'**** code
from CAO
If linkSel Is Nothing Then
    MsgBox "No
link!"
    Exit Sub
' Get selected link
Dim link As
CAO.link
Set link = linkSel.Item(SpinButtonLinkIndex.Value - 1)
If
link Is Nothing Then
    MsgBox "Unable to retrieve
this link"
    Exit Sub
pick.AddItem link.objectId '<---- gives a
"Object does not support method" error
Is there a way to convert the linked entity’s ObjectID
into a format, which the selection set method will accept?
Or is the another
way to accomplish this?
Hi Omar. The AddItems method expects an array of AcadEntity even if it is
only a single object. If all you have is the ObjectID, convert it to an
object by using the ObjectIDToObject method then add the resulting object to
an array. Finally, feed the array to the AddItems method. BTW, I'm not
familiar with automating MAP so please bear with me but is a link a
selectable object? If not, you can't add it to your selection set.
Get free software and more at
http://msnhomepages.talkcity.com/protectionfault/foquendo
"Omar Melo" wrote in message
news:87mq72$i3511@adesknews2.autodesk.com...
I was trying to add an entity to a selection set. I'm hacking up your CAO
Dim pick As AcadSelectionSet
Do While .Count > 0
.Item(0).Delete
Loop
End With
Set pick = ThisDrawing.SelectionSets.Add("omar")
pick.Clear
'**** code from CAO
MsgBox "No link!"
Exit Sub
' Get selected link
Dim link As CAO.link
If link Is Nothing Then
MsgBox "Unable to retrieve this link"
Exit Sub
pick.AddItem link.objectId '<---- gives a "Object does not support
method" error
Is there a way to convert the linked entity's ObjectID into a format, which
Or is the another way to accomplish this?
Thanks for looking at my problem Frank
I continued messing with it and located something that would let me use the
ObjectID.
I replace bad code:
>method" error
with
Dim tempObj As AcadObject
Set tempObj = ThisDrawing.ObjectIdToObject(link.objectID)
How can I now take the object and covert it to an array so it can be added
to a selection set?
Frank Oquendo wrote in message <87mqgp$i3e6@adesknews2.autodesk.com>...
to
> Do While .Count > 0
> .Item(0).Delete
> Loop
> End With
> pick.Clear
> '**** code from CAO
> MsgBox "No link!"
> Exit Sub
> End If
> ' Get selected link
> Exit Sub
> End If
>method" error
Using the code from your most recent post, you would just need to add
something like this:
Dim objArray(0 to 0) As AcadEntity
Set objArray(0) = tempObj
pick.AddItems objArray
Get free software and more at:
news:87n6ej$ke17@adesknews2.autodesk.com...
the
> ObjectID.
> I replace bad code:
> >method" error
> with
> to a selection set?
> to
> > Do While .Count > 0
> > .Item(0).Delete
> > Loop
> > End With
> > pick.Clear
> > '**** code from CAO
> > MsgBox "No link!"
> > Exit Sub
> > End If
> > ' Get selected link
> > Exit Sub
> > End If
> >method" error
which
