Add text in paper space
I am trying to add a simple line of text to paper space using VBA with a specific insert point.  I'm sure it is a very simple code, but nothing I try works.
Thanks in advance!
grobnik
Hi @Anonymous
the code below it's coming from Autocad Help so nothing of special procedure, probably you didn't insert Set before apply the Addtext function.
Sub InsertTextPaperSpace()
Dim InsPoint(0 To 2) As Double
Dim TextToInsert As String
Dim TextObj As AcadText
Dim Height As Double
InsPoint(0) = 25
InsPoint(1) = 35
InsPoint(2) = 0
TextToInsert = "TEXT TO INSERT"
Height = 25
Set TextObj = ThisDrawing.PaperSpace.AddText(TextToInsert, InsPoint, Height)
ThisDrawing.Regen acAllViewports
ZoomAll
End Sub
See picture below for procedure functionality confirmation
Let us know
That is exactly what happened.  Thanks so much for your help.  Anyway I can make this text I am inserting a certain color?  It is easy to change manually but would be nice to have it come in the color I want.
grobnik
Hi @Anonymous
Once you have the text object
TextObj
This will have some properties, look at debug, you can change color, font, and so on, add special char.
If you want to use true color for example it's more or less different see below code:
Dim color As AcadAcCmColor
Dim sVer As String = Left(acadDoc.GetVariable("ACADVER"), 2)
Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & sVer)
'Above automatic Get Cad Version, below manual.
'Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.20")
'For Acad2015, use AutoCAD.AcCmColor.20
'For Acad2016/17, use AutoCAD.AcCmColor.21
'For Acad2018, use AutoCAd.AcCmColor.22
'For Acad2019, use AutoCAD.AcCmColor.23
Call color.SetRGB(80, 100, 244) ' Set RGB colors as you want
TextObj.TrueColor = color
You will find a lot of literature on forum about text properties.
grobnik
Hi @Anonymous
sorry there is a mistake in the code here below the complete code working with color changing too:
Dim sVer As String
sVer = Left(AcadApplication.Version, 2)
Call color.SetRGB(88, 99, 115) ' Set RGB colors as you want
InsPoint(0) = 25
InsPoint(1) = 35
InsPoint(2) = 0
Height = 25
ZoomAll
End Sub
