Add line to selection set
how could I add a drawn line directly to an existing selection set?
In my example there is a layer based selection set called "SSetM" with 60 elements. Now I set up a line by "Set Linie1 = ZielDxf.ModelSpace.AddLine(pt1,pt2)" and want to add it to the existing selection set by "SSetM.AddItems (Linie1)".
What is the rigth way to do this?
Thanks in advance!
Lars
Alfred.NESWADBA
The parameter for AddItems is an array, not a single object.
So you have to create an array, add your object to that array and then add this array to your selectionset.
Public Sub test()
   'create the line
   Dim tLine As AcadLine
   Dim tPnt1(0 To 2) As Double
   Dim tPnt2(0 To 2) As Double: tPnt2(1) = 5.9
   Set tLine = ThisDrawing.ModelSpace.AddLine(tPnt1, tPnt2)
   'create the selectionset
   Dim tSelSet As AcadSelectionSet
   On Error Resume Next
   Set tSelSet = ThisDrawing.SelectionSets.Add("XX")
   If tSelSet Is Nothing Then
      Set tSelSet = ThisDrawing.SelectionSets.Item("XX")
      tSelSet.Clear
   'add the line to an array
   Dim tArr(0) As AcadEntity
   Set tArr(0) = tLine
   'add the array of object to the selection-set
   tSelSet.AddItems (tArr)
   Call MsgBox("Entities in SelectionSet: " & CStr(tSelSet.Count))
End Sub
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks, Alfred.
I thought that I've tried it this way...anyway this time it works.
You could also try just using
SSetM.Select acSelectionSetLast
Right after the AddLine() statement
Thanks a ot for the hint. This way it works as well.
