add area to attributs of block
Message 1 of 9
hi
i want know how to add area value of close polyline to attribute of block.
think you
Replies (8)
Message 2 of 9
billy del casa wrote: > hi > i want know how to add area value of close polyline to attribute of block. > think you I have one for lisp if you like. This routine you select the closed polyline then pick the Drainage area block to insert the area in Acres into the block. you can change the name and the attribute to suit your needs. (defun c:acb (/) (setq OS (getvar "osmode")) (setvar "osmode" 512) (while (/= (cdr (assoc 0 (entget (car (setq ENT (entsel "\nSelect Polygon ")))))) "LWPOLYLINE")) (redraw (car ent) 3) (setvar "osmode" OS) (command ".area" "e" ENT) (setq Area (getvar "area")) (setq Acre 43560) (setq a (/ area acre)) (princ " ") (princ a) (princ " Acres ") (princ area) (princ " S.F.") (princ) (while (/= (cdr (assoc 2 (entget (setq ename1 (car (entsel "\nPick block")))))) "DS Draiange area Marker")) (setq ename2 ename1) (while (/= (cdr (assoc 2 (entget (setq ename1 (entnext ename1))))) "AREA_IN_ACRES")) (setq ent1 (entget ename1)) (entmod (subst (cons 1 (rtos a 2)) (assoc 1 ent1) ent1)) (entupd ename2) (redraw (car ent) 4) (princ) )
Message 3 of 9
Speed_CAD
Hi...
I did this routine 😉 to VB
Private Sub AreaPolyAtr()
Dim AreaPol As String
Dim objsel As AcadLWPolyline
Dim pnt As Variant
Dim enTipo As String
Dim coordenadas As Variant
Dim Atributo As AcadAttribute
Dim I As Integer
Dim xl, yl, zl
Dim xyz As Integer
Dim X, Y
Dim coor
Dim punto(0 To 2) As Double
Dim Bloque As AcadBlock
Dim RefBloque As AcadBlockReference
xl = 0: yl = 0: zl = 0: xyz = 2
On Error Resume Next
Err.Clear
utilGet.GetEntity objsel, pnt, vbCr & "Seleccione Polilínea: "
enTipo = objsel.ObjectName
If enTipo = "AcDbPolyline" Then
coordenadas = objsel.Coordinates
For I = LBound(coordenadas) To UBound(coordenadas)
If (I - (xyz * (Fix(I / xyz)))) = 0 Then
xl = xl + coordenadas(I)
If (I - (xyz * (Fix(I / xyz)))) = 1 Then
yl = yl + coordenadas(I)
If (I - (xyz * (Fix(I / xyz)))) = 2 Then
zl = zl + coordenadas(I)
Next I
AreaPol = "Area: " & Format(objsel.Area, "0.000")
X = xl / ((UBound(coordenadas) + 1) / xyz)
Y = yl / ((UBound(coordenadas) + 1) / xyz)
punto(0) = 0: punto(1) = 0: punto(2) = 0
Set Bloque = acadDoc.Blocks.Add(punto, objsel.Handle)
Set Atributo = Bloque.AddAttribute(4.5, acAttributeModeVerify, "AREA:", punto, "A", AreaPol)
Atributo.Alignment = acAlignmentMiddle
Atributo.TextAlignmentPoint = punto
Set RefBloque = acadDoc.ModelSpace.InsertBlock(punto, objsel.Handle, 1, 1, 1, 0)
punto(0) = X: punto(1) = Y: punto(2) = 0
RefBloque.InsertionPoint = punto
Else
MsgBox "Debe seleccionar una polilinea."
End Sub
Un saludo de SpeedCAD... 🙂
CHILE
FORO: http://www.hispacad.com/foro
Mauricio Jorquera
Message 4 of 9
think you four your help, but i have always the problem.
j'ai executé le programme en VB mais ça n'a pas marché. si c'est possible vous m'ecrirez les etapes pas à pas(step by step) dés la creation du bloc avec l'attribut surface (area) jusqu'à le calcul et l'affichage de cette surface par autocad.
think you
Message 5 of 9
Speed_CAD
Hi...
You talk in English please...
Mauricio Jorquera
Message 6 of 9
Babel Fish Translation In English: I have executed the program in VB but ?? does not have ??. if it is possible will you write the stages not ?? pas(step by step) ?? the creation of the block with the attribute surfaces (area) until ?? the calculation and the posting of this surface by autocad. SpeedCAD wrote: > > Hi... > > You talk in English please... -- Anne Brown Discussion Groups Administrator Autodesk, Inc.
Message 7 of 9
Here is the translation:
I ran the program in VB but it didn't work. If possible could you write it step by step from the block creation with the area attribut up to the calculation and printing of this surface by Autocad.
Message 8 of 9
Drummond's translation is perfect.There is someone who speaks English-French or French-English ( as you prefer) at last 😉
Message 9 of 9
Speed_CAD
Thanks Drummond...
Ok, First you reference to AutoCAD 2000 Type Library or AutoCAD 2004 Type Library. Next:
Option Explicit
Private autocadApp As AcadApplication
Private utilGet As AcadUtility
Private Sub Form_Load()
Set autocadApp = GetObject(, "Autocad.Application.15")
'If AutoCAD 2004 then
'Set autocadApp = GetObject(, "Autocad.Application.16")
Set utilGet = autocadApp.ActiveDocument.Utility
End Sub
Dim pnt As Variant
Dim I As Integer
Dim xl, yl, zl
Dim xyz As Integer
Dim X, Y
Dim coor
Err.Clear
Next I
Else
End Sub
Private Sub CommandButton_Click()
AppActivate autocadApp.Caption
AreaPolyAtr
Me.Show
End Sub
Is All
CHILE
Mauricio Jorquera
