ActiveX DLL loading
ActiveX DLL loading
ActiveX DLL loading
I am having a problem getting my ActiveX DLL to load. I am using the
following code:
(setq obj (vlax-create-object "Steel.StlUtil"))
My file is called Steel.dll and i have 2 seperate class files:
Channel(channelform.cls)
StlUtil(utilities.cls)
when I run this code all I get is NIL after.
The dll file works fine when I refenence it inside a Visual Basic EXE
program.
Any help will be appricated
I am new at ActiveX and this my first attempt at this.
I am going to post the DLL fine in customer files NG.
Thanks.
Lenny
Try this instead.
(setq *Application* (vlax-get-acad-object))
(setq obj (vla-getinterfaceobject *Application* "Steel.StlUtil"))
You may also want to note that vlax-invoke-method does not appear to work.
Instead, use vlax-invoke.
I believe the latter method has been deprecated, but since it is the only
one I can get to work, it is what I use.
Chuck
"Lenny Louque" wrote in message
news:BA85E0E3CA4B3718FDE0708E1A2D8C39@in.WebX.maYIadrTaRb...
> following code:
> program.
> Thanks.
> Lenny
I am now getting a different error:
; error: Automation Error. Problem in loading application
Any idea what could be causing this? Does this mean my DLL might be
incorrect?
Thanks.
Lenny
"Chuck Gabriel" wrote in message
news:4FF1751A5E0022BB52C7447D5C145422@in.WebX.maYIadrTaRb...
> Try this instead.
> Chuck
> > following code:
> > program.
> > Thanks.
> > Lenny
Are you certain "Steel" is the correct library name?
I doubt there is anything wrong with your DLL, since, as you mentioned
before, it works fine in VB.
news:06DD70E426383856A8117EAD1B5BAD1A@in.WebX.maYIadrTaRb...
> incorrect?
> Thanks.
> Lenny
Did you call (vl-load-com) before you tried to create the object?
> incorrect?
> Thanks.
> Lenny
