ActiveViewport properties do not change on user input
One can set things like camera position and target using
ThisDrawing.ActiveViewport = "some Viewport object with defined properties".
Works fine.
Now my problem:
when I change the 3d view in autocad using for exaple the orbit icon, these
changes are not reflected in the ThisDrawing.ActiveViewport's properties.
whenever I read values like Direction, they keep the same. Why do these
values not update on user input directly in autocad?
Issuing ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport resets the
view to the previous state. I tested commands like Regen or Update, but no
effect. Eventually the problem is not the graphical representation on
screen, but the properties of the object.
So how can I keep track of a changed view in my application??
many thanks, Rainer
Thisdrawing.save works
> schrieb im Newsbeitrag news:5087764@discussion.autodesk.com...
thanks for that hint. but shouldn't that be seen as a bug in autocad, not
updating the ActiveViewports properties on user input...
RonnieWilkins
Not a bug. By design.
Even in ARX or Managed ARX (.NET) you have to manually update a viewport using acedVports2VportsTableRecords. I have this working in VB.NET, never tried in VB not sure if it can call the exported function correctly, though it should.
You can view the thread here:
http://discussion.autodesk.com/thread.jspa?threadID=455076
Ronnie Wilkins, Jr.
