AcadDocument_BeginCommand
Hi all,
If I were to do an If statement that was triggered when the grip on a line was selected to stretch.
How would I in that If statement have code to recognize the line selected automatically?
Mike
Did you try
Private Sub AcadDocument_ObjectModified(ByVal Object As Object)
If TypeOf Object Is AcadLine Then
MsgBox "LIne"
End Sub
Thanks, I like it.
Cheers,
Mike
Hi, one more question then. Is there a property I can access to get the properties of the line BEFORE it was updated.
Basically I need to get the properties when it's first selected and then I'll use the Object Modified once its been changed to make a comparison.
Is there a "Object Selected" property?
Cheers,
Mike
Do a search for xdata
