Acad 2014 to Access-Run-time error 429 Activex component can't create object.
Message 1 of 12
We have a VBA program that takes attributes from Autocad to an Access program. In Acad 2013 it works fine but now in 2014 it doesn't.
Both versions of Autocad are on the same environment of
Windows 7 64bit
With the 64bit versions of BOTH software - Autocad and the VBA expansion.
The program doesn't work in 2014 and since 2014 was installed it won't work in 2013 either.  So now we have unloaded the VBA expansion pack for BOTH 2014 and 2013 and then reloaded the 2013 back on and it seems the 2013 version is running again. Error code is: Run-time error 429 Activex component can't create object.
The Access Database may now be a sequel database with an Access front end but the case is 2013 works and 2014 doesn't?
Any ideas?  I don't think it would be a 32 vs 64 bit because the 2013 version works?
Thanks in advance
Replies (11)
Message 2 of 12
fxcastil
In AutoCAD verisons 2013 and older VBA is a 32bit application, that is why AutoCAD VBA runs slow on 64bit AutoCAD. In AutoCAD version 2014 (64bit), VBA is now a new version of 64bit VBA.
  http://blog.jtbworld.com/2013/03/autocad-2014-supports-vba-64-bit.html
So when you say you
"So now we have unloaded the VBA expansion pack for BOTH 2014 and 2013 and then reloaded the 2013 back on and it seems the 2013 version is running again." I'm not sure what you mean.
To try and clarify
1) AutoCAD 2014 (64bit) uses 64bit VBA.
2) AutoCAD 2014 (32bit) uses 32bit VBA.
3) AutoCAD 2013 (64bit) uses 32bit VBA
4) AutoCAD 2013 (32bit) uses 32bit VBA
I would not try and run 32VBA and 64bit VBA on the same computer.
The new 64bit VBA should run much faster than the older 32bit VBA, but there will be compatibilty issues with other 32bit applications.
http://msdn.microsoft.com/en-us/library/office/ee691831(v=office.14).aspx#odc_office2010_Compatibili...
Message 3 of 12
ALL Autocad and VBA versions are 64bit I have not put on ANY 32bit applications. I unloaded the VBA expansions on both 2013 and 2014 and then reloaded 2013 to try to get a fresh install to jog the system to work in 2013 again - with success.
It is a mistery to me why 2013 works and 2014 doesn't?
Message 4 of 12
Looks like the issue maybe Microsoft:
http://support.microsoft.com/kb/957570
Still doesn't explain why VBA 2013 64bit does work!!!
Message 5 of 12
fxcastil
VBA 64Bit is only available for AutoCAD 2014 and NOT for earlier version of AutoCAD.
Once again AutoCAD 2013 uses 32bit VBA.
1) 2013 AutoCAD 32bit    -  uses VBA 32 bit.
2) 2013 AutoCAD 64bit    -  uses VBA 32 bit.
3) 2014 AutoCAD 32bit   -  uses VBA 32 bit
4) 2014 AutoCAD 64 bit  -  uses VBA 64 bit.
Message 6 of 12
I'm sorry I must have missed the 32bit part as in the download page it has it as a 64bit download. So you must be saying the 64bit download is just the 32bit program moded a bit to do the 64bit part?
This would explain it!
See: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12715668&linkID=9240618
Message 7 of 12
fxcastil
The download page you show is a bit (very)  confusing, because the description would lead you to belive the 64 bit and 32 bit refer to VBA. But 32 bit and 64 bit actually refer to the AutoCAD 32bit or AutoCAD 64 bit versions.
No where in link below does it clarify the Version of VBA that is being downloaded.
That is why I provided the link below
You will notice there is a difference in the Visual Basic editor for 32bit and 64Bit VBA. If you go the the Help/About pull-down menu, VBA 64 Bit is version 7.1.
Message 8 of 12
Thanks for your reply. I think I will learn VB.net to get around the problem or write it in visual lisp.
Message 9 of 12
Rob.O
So is there an actual solution to this other than re-writing everything in .NET?  I have already started the rewrite process, but have 10 years of VBA code to rewrite in .NET and just need a crutch until I can get it all finished.
We only have a handfull of machines (4-5) that run Win7 64bit.  The rest are all XP machines.  If there is no easy solution, then I guess we will continue to run AutoCAD 2012 until I can get all of the important code re-written in .NET (at least another year).  😞
It looks like our biggest issue is the 32bit OLE DB providers and MS Access.  Another reason I have started converting everything over to .NET and SQL!
Message 10 of 12
No the solution you are doing is pretty much it but you could convert your code to Visual lisp. Just another avenue you could go down.
Looks like VBA is getting the flick!
Message 11 of 12
Rob.O
Grant,
I just wasn't satisfied that there was not a workaround for this, so I re-read a thread I had started a couple of years ago:
http://forums.autodesk.com/t5/NET/32bit-AND-64bit-environment-database-connectivity/td-p/2925668/pag...
I thought I had tried everything that was suggested in that thread, but I think I missed one crucial piece.  In the second to last comment, someone posted that you could load the 64bit MS Access Database Engine on a system with MS Office 32bit by using the /passive parameter to install it.  Success!!!  It worked!  The 64bit engine installed, I added a reference to the code and blam... old vba code connecting to Access .mdb files in AutoCAD 2014 64bit!!!
I now have my crutch! 🙂
Message 12 of 12
fxcastil
There is another option to allow to to use you VBA routines on a 64Bit Windows computer.
There is a company (Longbow Software) which allows you to install 32bit Autocad on a 64bit Win7 computer.
There is a memory limit about 3Gb for 32bit AutoCAD installed on a 64bit Win 7 computer.
If your cad files are not extra large > 15MB-20MB you will not see a memory limit problem.
You may be surprised that AutoCAD 32 bit is not slower than 64 bit AutoCAD on the 64bit Win 7 computer.
The other benefit of using the Longbow Software and installing a 32 bit version of AutCAD, is that the VBA programs will run fast. You have probably noticed how slow VBA programs are when running on 64bit AutoCAD on a Win 7 computer.
I would recommend anyone wanting to keep using their old VBA software try the longbow software, I have been able to continue to use my older VBA programs on a newer Win 7 64 bit computer, and the VBA programs run at the faster speed,
Search this site for Longbow.
http://www.longbowsoftware.com/
