A question about Nothing
Message 1 of 15
Hi
I understand what Nothing does:
Set MyObject = Nothing
But I don't understand the reason for it.
Especially at the end of a routine
Doesn't End Sub do the same thing?
Dave F.
Replies (14)
Message 2 of 15
I believe it unloads it from memory. I may be wrong though.
Tim Riley
"Dave F" wrote in message
news:1789035C898EEE36465216489561B600@in.WebX.maYIadrTaRb...
> Hi
> Dave F.
Message 3 of 15
It's insurance. While VB/A is quite good at cleaning up after itself, it
doesn't hurt for *you* to clean up afte yourself. It also makes the
object's life cycle quite obvious which is handy during debugging.
There are 10 kinds of people. Those who understand binary and those who
don't.
http://code.acadx.com
(Pull the pin to reply)
Message 4 of 15
"Dave F" wrote in message news:1789035C898EEE36465216489561B600@in.WebX.maYIadrTaRb...
> Hi
Yes, and doing it explicitly is entirely pointless.
The only time that you need to explicitly set a
local object variable to Nothing, is if the code
that follows depends on a side-effect of the object
destroying itself, or when you want to control the
order in which multiple, interdependent objects are
destroyed.
A good example of this would be an ObjectDBX document
which you need to move/rename after accessing it via
ObjectDBX. Since the only way to release the lock on
the .DWG file is by destroying the AxDbDocument object,
if you wanted to rename the .DWG file after you've
finished accessing it, you would first have to set the
AxDbDocument variable to Nothing, to release the lock
on the file.
AcadXTabs: Document Tabs for AutoCAD
http://www.acadxtabs.com
Message 5 of 15
Hi Tony,
Since you're talking about destroying files by setting to nothing, I had a
related question on another thread.
if I were to open a file thus
sResult=
CreateObject("Scripting.FileSystemObject").OpenTextFile(fname).ReadAll
does that open file handle get closed when the sub terminates and sResult
goes out of scope? or maybe even immediatly after .Readall???
or is there somehow a transient bit of memory floating around that still has
the file open? also curious about the fso object that was created, since
theres no variable pointing to it, how and when is it released? magically
and instantly as soon as it's done it's work?
it doesn't put a lock on the file so there's no problem with subsequently
opening it in for example, notepad, but i was just curious about a second
opinion.
"Tony Tanzillo" wrote in message
news:DD6601BF9312A0A9DCC34B59971E34F3@in.WebX.maYIadrTaRb...
> > Hi
> destroyed.
> on the file.
Message 6 of 15
> destroyed.
So you're saying it's *not* entirely pointless?
don't.
Message 7 of 15
"Mark Propst" wrote in message news:3898213F33E7FEE87FCE0E03B8ADA2DD@in.WebX.maYIadrTaRb...
> Hi Tony,
> sResult=
OpenTextFile returns a TextStream object, which has a Close()
method. My guess is that the file is closed when the TextStream
object is destroyed, but don't hold me to it.
Message 8 of 15
> sResult=
Just checked, and the file is indeed closed automatically
when the TextStream object is destroyed.
Message 9 of 15
If you dont do this , MyObject will still hold referance to the object.
To check it create an AcadApplication object and dont use Set MyObject =
Nothing at the end.
when u shutdown the machine, it will popup a dialog box indicating the
object is still being referred to.
> Hi
> Dave F.
Message 10 of 15
Do you have an example?
Message 10 of 15
Message 12 of 15
Thanks Tony,
just curious, how did you check that the file was closed?
since it wasn't set to a variable I couldn't think of a way to know if a
copy of it was still being held in memory or not.?
is there a way to actually "look"at memory to see what's there?
news:80A8283AF86BC15ED00F18BD3687D030@in.WebX.maYIadrTaRb...
> > sResult=
sResult
Message 13 of 15
I'm guessing this would tell. I haven't tried it myself.
http://www.sysinternals.com/ntw2k/freeware/handle.shtml
LJB
Message 14 of 15
Actually this one is better
http://www.sysinternals.com/ntw2k/freeware/procexp.shtml
I tried it but failed to detect the file I used opening. Probably because
the duration was too short.
LJB
Message 15 of 15
cool, thanks
Mark
"ljb" <.> wrote in message
news:0159983D3BDF7982237CDD6ABD6DF960@in.WebX.maYIadrTaRb...
> LJB
