64 Bit ObjectID
64 Bit ObjectID
64 Bit ObjectID
Help! i can't seem to get the object ID in 64 Bit autocad! i can get an objectID from ObjectID32, but it doesn't work... what i'm doing is grabbing the object id for a viewport and using that to make a field for the scale value... but alas, it errors on me if i use just ObjectID, but if i switch to ObjectID32 the field returns ####. i can manuely set it, but that defeats the automation part... stupid! so, is there a way to get the object id that anybody knows about?
here's my code:
Public Property Get ViewportScaleField() As String
Dim vp1 As AcadPViewport
Dim vp1pt1 As Variant
Dim objid As String
Dim scale_field As String
For Each layer In ThisDrawing.layers
If UCase(layer.Name) = "VP" Then
layer.LayerOn = True
layer.Freeze = False
Next
Dim errornum As String
pickviewport:
On Error Resume Next
ThisDrawing.Utility.GetEntity vp1, vp1pt1, vbLf & "Select Viewport: "
errornum = Err.Number
If errornum = -2147352567 Then
ThisDrawing.Utility.Prompt vbLf & "Prematurly Ended "
Exit Property
If Not errornum = 0 Then
ThisDrawing.Utility.Prompt vbLf & "Not a Viewport... Try Again "
GoTo pickviewport
objid = vp1.ObjectID
scale_field = "SCALE: " & "%<\AcObjProp Object(%<\_ObjId " & objid & ">%).CustomScale \f ""%lu4%pr8%ct2%qf2816 = 1'-0\" & Chr(34) & Chr(34) & ">%"
ViewportScaleField = scale_field
End Property
Look on the AcadUtility object for a method that returns
the
objectid as a string (sorry, forget what it's
called).
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
Help!
about?
here's my code:
As String
Dim
objid As String
For Each layer In
ThisDrawing.layers
Then
        layer.LayerOn =
True
        layer.Freeze =
False
        End
If
    Next
Dim errornum As
String
pickviewport:
    On Error Resume
Next
    errornum =
Err.Number
Then
Exit Property
        End
If
    If Not errornum = 0
Then
        GoTo
pickviewport
        End
If
scale_field
End Property
