2010 dbx
2010 dbx
2010 dbx
Cannot run dbx in 2010 Autocad. Error message is "x64VBAServer has stopped working" if I try to access the AXDBLib and if I run the code the dbx variable is never set with the error message "Object variable or With block variable not set"
are you on 32 or 64 bit system?
sounds like a mismatch
wrote in message news:6401677@discussion.autodesk.com...
variable not set"
