Hallo Vault team,
regarding the project and engineering process in Autodesk Vault with Inventor users do not know if a linked drawing needs to be updated or not! If an assembly is released and the user is working on a change during a state change it is not evident if a drawing ist up to date. This is a big problem with Vault jobprocessor export of PDF files!
The jobprocessor is doing a FastOpen of idw/dwg files without a get of 3D CAD model file (ipd, iam) to finish jobs more quickly. So if a user changes a 3D CAD model - for example a ipt-file- and does not open the linked drawing (idw/dwg) in Inventor to update and save it before releasing the PDF export is not correct.
Additionally the properties ar up to date on the draring head and the view in drawing ist old!
Possilble solution:
Is it possible to add a new property in Vault to see if a dragin needs to be updated?
It would be possible for users to filter through files in a project to see which drawings they need to update!
Additionally it would be nice to see it on ALL parent files (iam, ipt, idw, dwg). Also Assemblies need to be opend and saved in INventor in order to have an updated version of files in Autodesk Vault!
This would be a nice feature for all our Vault Workgroup and Vault Professional users!
Best regards!
Dominik
