I would like an easier way to navigate to drawings from within the Thin Client Forge Viewer. Currently, if you have an assembly open for viewing, you cannot see what parts have existing drawings. There is also no way to quickly navigate to a part's drawing even if you knew one existed. We would like those on the shop floor to use the Thin Client so they have access to the latest released files. The idea is they can access the shop drawings relevant to a particular project quickly and easily, without needing to constantly ask our CAD designers to print missing drawings. The easiest way to visualize a project is through the 3D viewer. Currently, we have to batch plot pdfs for each project to a folder on our network, but this runs the risk of files being out of date and defeats the purpose of Vault.
A solution could be similar to what I propose below. (See attached proof of concept image)
- When right-clicking a part, have an extra option in the menu that will open that part's drawing in a separate tab. If no drawing exists it would be greyed out. Similar to how it works in Inventor.
- Have an extra column in the model browser, that quickly indicates each part that has a drawing. Clicking on the symbol will open that drawing in a separate tab.
- Have a drawing tab up top, to quickly switch to the top-level drawing for this particular assembly/part.
If there are multiple drawings for a particular assembly or part, you should be given the option to pick the one you want to open.
If a solution to this is implemented it will make the Thin Client much easier to use, especially for those who aren't particularly computer savvy.
