Show only
Search instead for
Current Generic Error message on Lifecycle Transition
Please support a detailed error message which explains which specific criteria is not compliant, so the end user can make the changes without having to troubleshoot the missing criteria.
Currently if there are criteria requirements for a lifecycle transition and they are not met, the user gets a somewhat cryptic message that doesn't tell them what they need to change.
Given that the criteria are based on properties, they should be much more specific, i.e.
Lifecycle Definition: Standard Release
Transition: WIP->Review
Transition not allowed due to criteria:
Linked to Item is "Yes"
Description is not null
This way the user would immediately know what needed to be done to change the lifecycle state. Other systems even offer an "Audit" function that will evaluate the object without attempting to make the transition.
We like to use the criteria to avoid cunstom programing, but without useful error messages this function is useless! Please implement this fast!
In the meantime: Is there a way to customize the current error message? Current message is: "One or more files cannot change to the specified state due to errors or restrictions".
If we could customize the message to give some hints it would help!
