Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Improve Vault Installer Pre-Checks to Fully Support HTTPS Configurations (e.g. Vault Professional 2026)
During the upgrade to Vault Professional 2026, the pre-check tool fails when IIS is configured with valid HTTPS bindings and an SSL certificate — even when everything is functioning correctly and accessible over HTTPS.
Problem Observed:
  • The installer attempts to access the file:
    http://localhost:443/TestASP/TestASPNetStatic.txt
    This is an invalid use of port 443, which is reserved for HTTPS.
  • This causes a false failure in the pre-check step "Checking ASP Status", even though:
    • IIS bindings are correctly set to "All Unassigned"
    • HTTPS is enabled and working
    • The certificate is valid and trusted under its assigned domain
Root Cause:
  • The pre-check tool is hardcoded to test localhost over HTTP, even when SSL is enabled.
  • It does not validate or accept HTTPS responses, nor does it adapt to hostname + certificate logic.
  • Users must resort to a workaround: temporarily removing HTTPS bindings from IIS to pass the installer check, which introduces risk and adds unnecessary steps.
Recommendation:
  1. Update the Vault installer logic to support and properly verify HTTPS bindings.
  2. Adjust the ASP test to use the correct URL scheme:
    https://<server-FQDN>/TestASP/TestASPNetStatic.txt
  3. Ensure the pre-check respects:
    • IIS bindings using "All Unassigned"
    • SSL certificates matching the FQDN or SAN
    • Functional HTTPS responses (including from internal or self-signed certificates)
Benefit:
This improvement would streamline enterprise deployments, eliminate unnecessary workarounds, and align Vault installation workflows with modern IT and security standards.
4 Comments
ihayesjr
Status changed to: Accepted
ihayesjr
Fixed in Vault 2027
michel_coulon
Observer
Fix it also for Vault 2026 - We cannot implement Vault 2027 on our server (dot.net 10 not allowed)....
ihayesjr
@michel_coulon
Install fixes are only resolved in newer versions of the product. We cannot patch a released installer version.
