Dynamic/Virtual Tree view based on Properyvalues
I want to be able to navigate in a virtual tree environmet based from the properties on each file.
This is a feature I remeber using in Automanager Workflow a long time ago.
This makes it easy to find the files you are looking for.
Example: I would like to create a view based on Created by, Project and User Status or Project, User Status, Checked in by
This makes it easy to fine the files I am working with in each project and I can see all files that are in Work in progress.
I guess that creating a dynamic treeview for all files in a vault might be to much and mayby it should be used in combination with search-folders or as a rightclick on a subfolder i the treeview
Dynamic-View
4 Comments
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
AndriesMuylaert
