DWG underlay missed at Viewer
User missed the DWG underlays at Vault Viewing and Vault webclient Viewing.
Picture 1: At thumbnail the DWG underlay is visible
Picture 2: At Vault Vewer the DWG underlay is missing at Viewing
Why the difference? The DWF File "lost" / "ignore" the DWG underlay!
At Modell-Browser Button user can't visible the DWG underlay - "That's a shame"
2024-01-18 08_49_44-Autodesk Vault Professional 2024.png2024-01-18 08_51_30-Autodesk Vault Professional 2024.png
10 Comments
ihayesjr
@Uwe_Lindner
Thank you for posting the idea. If you upload your DWG to viewer.autodesk.com, do you see the underlay?
Uwe_Lindner
Yes, we can see the DWG underlay in Viewer.
See my 30 Days View
https://autode.sk/3V37fdD
ihayesjr
You published the drawing not the Inventor Model.
Inside of Inventor, export the model out to a DWF file.
Open the DWF file in ADR.
Is the underlay missing?
Uwe_Lindner
I have create a new IAM with DWG Underlay inside.
see result at https://autode.sk/3T6KMtt
2024-03-06 07_36_31-Autodesk Vault Professional 2024.png2024-03-06 07_37_08-Autodesk Vault Professional 2024.png2024-03-06 07_38_13-Autodesk Vault Professional 2024.png
Uwe_Lindner
And It's no difference if you start with a "Standard.IAM" an make AnyCAD insert DWG or you start with a "StandardFactorylayout.IAM" and add the DWG as "DWG_Underlay"
Result at viewer ist the same - Model is empty!
2024-03-06 07_44_58-Autodesk Vault Professional 2024.png2024-03-06 07_45_18-Autodesk Vault Professional 2024.png2024-03-06 07_46_14-Autodesk Vault Professional 2024.png
ihayesjr
Thanks. This means that this issue needs to be resolved in Inventor.
ihayesjr
@Uwe_Lindner
Open the assembly in Inventor and use the Shared Views command.
What do you see?
Uwe_Lindner
Inventor get a information Dialog that DWG-Underlay not possible at shared View.
From our perspective a gap at the process - and pain for customer!
Users need a possibility to see the DWG underlay in combination with the 3D models at the viewing tools.
ihayesjr
Status changed to: Archived
Thanks for the information. Please log an Idea on the Inventor's Idea board.
Uwe_Lindner
Idea at Inventor's Idea Board is createt
DWG underlay missed at Viewer - Autodesk Community
Thank You!
